Need OME rear spring advice please.
Old Jan 29, 2015 | 04:50 AM
remac's Avatar
As a preface this site rocks! I have read everything I can but am still confused as to which rear springs. I have a 97 SR5 2wd 4runner. I have a ARB Tacoma front bumper and 9500lb winch up front with fresh (3 days old) OME 881 springs and Bilsteins. I can't remember my original measurement on the beat springs but I am sitting right around 36" from the ground to the fender flare in the front and 34ish in the rear. I am thinking OME 890 or 906 for the back. I do hunt and fish a lot and pull a small duck boat but the majority of the time I is loaded like it is. I do not mind some rake but do not want a ton. So which rear springs 906 or 890?
Old Feb 3, 2015 | 12:54 PM
Keith B.'s Avatar
I have 881s in front and 890s in the rear(on a 4WD 97). The rake is perfect for me, meaning that when I've got 500-700 pounds of stuff in the back, the truck is level.
Wish I'd gotten Bilsteins instead of OME shocks....the OMEs are lumber truck stiff when empty, but maintain a nice firmness when loaded.
Bilsteins, based on my previous experience on torsion bar and leaf spring Toyota trucks, are a less brutal shock that seem to have a more advanced, speed- and amplitude-sensitive valving.
Old Feb 3, 2015 | 05:49 PM
MVP's Avatar
MVP
Would you also be looking at the 891 OMEs? If you are often loaded down or towing, they are more stout springs than the 890s.
I have the 890s in my unladen vehicle, but picked up some 891s in case my needs for towing or hauling change...
Old Feb 4, 2015 | 02:49 AM
remac's Avatar
I ended up going with 890s rear and Bilsteins. I am sitting right at 37 in the rear so 1" of rake. Biggest problem now is I need bigger tires. LOL. Should have gotten 880s front and probably would have been perfect but it does ride better since the factory stuff had 305k on it.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Iceman4193
Jul 15, 2015 04:48 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
