Antenna Replacement
Old Dec 2, 2014 | 01:30 PM
turkvu's Avatar
Antenna Replacement
Hi everyone - I have a 2000 4runner. Over the last 14 years the motorized antenna has gone out twice. The first time a about 10 years ago, the second time about 4 years ago. Think it's about time I went with a non-motorized solution.
I've searched and read about the Taco Whip Antenna, then I called my dealership and they want $72 for the antenna assembly 86300-35090. Most places online are charging $50...but it seems that the assembly doesn't include the mast any more so that would be another $40.
That seems excessive for an antenna - I see rubber ones with cable for ~$15 on amazon. Has anyone gone down this path and bought an aftermarket antenna assembly? Any recommendations for a cheaper solution than going with the toyota part?
Thanks for any and all suggestions.
--a
Old Dec 2, 2014 | 03:08 PM
turkvu's Avatar
Thinking about something like this:
http://www.stylintrucks.com/parts/re...rb501604-.aspx
Old Dec 2, 2014 | 04:49 PM
Robb235's Avatar
I used a universal antenna from O'Reilly Auto Parts (p/n CK-US07R).
Old Dec 2, 2014 | 06:45 PM
turkvu's Avatar
Looks great - I'll run over there tomorrow. Thanks.
Old Dec 3, 2014 | 12:40 AM
wyoming9's Avatar
Red face
I have used several different aftermarket ones with good results over the years.
I never had good luck with the ones you raise and lower by hand I think because they spent most of the time in the up right position .
If you run under lots of low branches and don`t want the hassle of removing it all the time . You might want to look at a spring loaded mount.
Old Dec 11, 2014 | 02:13 PM
turkvu's Avatar
I bought an aftermarket assembly from O'Reilly, along with a rubber replacement mast. Just installed today. Running the wire was a pain in the a - but it looks good, have good reception and best of all no more grinding motor every time I turn on the car.
Thanks for the help.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
