Driveshaft Length? 96 Taco
Old Jan 9, 2006 | 09:45 AM
MudMonkey's Avatar
Could someone please measure the rear section of their driveshaft, after the carrier? I think the previous owner may have lengthened it after he put lift blocks on the truck.
Thanks in advance.
Old Jan 10, 2006 | 10:30 AM
MudMonkey's Avatar
bump ttt
Old Jan 12, 2006 | 10:51 AM
rngrchad's Avatar
Mud monkey, I'll go measure....BRB.
Old Jan 12, 2006 | 10:57 AM
rngrchad's Avatar
my slipspline measures 7" from the end of the yoke to the beginning of the driveshaft.
Make sense? Anyhow, keep in mind without dropping my driveshaft, I can't really get you an accurate measurement on the slipspline itself.
Measurements will also differ depending on amount of load/lift/compression etc.
Old Jan 12, 2006 | 11:16 AM
MudMonkey's Avatar
I get the same measurement. Thanks.
Back to square one.
Old Jan 12, 2006 | 11:20 AM
rngrchad's Avatar
not a problem. fyi: my truck has a 1.5" AAL and a 1.5" coil spacers.
Old Jan 12, 2006 | 11:22 AM
MudMonkey's Avatar
I have 3" of susp. lift.......hmmm.....now I see a problem.
Old Jun 21, 2006 | 05:38 AM
dfoxengr's Avatar
sorry to bring this back but i didnt want to start a new thread.
on my 96 tacoma after doing my 3" lift i noticed the driveshaft extended about 1.5" from where it sat stock.
im wondering how much additional travel extension is in there, and if anyone has ever had problems with flexing and their shaft coming out.
-derek
Old Jun 25, 2006 | 09:21 AM
dfoxengr's Avatar
anyone have an answer?
Old Jun 25, 2006 | 10:04 AM
I built 17" of travel in the rear of my 1996 taco and use the original driveline. The stock Tacoma driveline is amazing. I had the center carrier bearing replaced by an awesome driveline builder and I asked him to make SURE everything was cool and balanced. I've really hit it hard a couple of times in the past while mobbing over rock barriers and it is scarred up a little. He said everything was fine that it's one of the best drivelines out there, being that it's 2 piece which allows for more clearance.
I have completely bottomed the thing out and never had any issues pop up. I inspect things all the time. Just make sure you grease it up every year or so. Don't put too much grease in the joints or it will splash the underside pretty good =]
Old Jun 25, 2006 | 07:02 PM
Tanto's Avatar
Derek, I've never seen or heard of the rear dshaft pulling apart at max flex. If you ever change out the leafs on your taco, you will be pleasantly surprised to see how much it can extend.
Old Jun 26, 2006 | 03:06 AM
dfoxengr's Avatar
yeah i already did, with some alcans.
thanks for the info.
-derek
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
Jwp1
Sep 6, 2015 11:03 AM
