Thump noise from rear
Old Jan 30, 2006 | 11:31 PM
4RUNN!N's Avatar
A weird thumping noise has been occuring in my 4R. Seems like its coming from the rear undercarriage, and I only hear it when I go over a large bump or low dip with a person or two in the back seat. I thought it might be the spare tire being loose and hitting the bottom, but its really secure, so that rules the spare out. I also thought it might be my sub box, but it's quite heavy and doesn't slide at all. My dad told me it might be the bump stops in the rear, but my spring rate feels the same and with people in the back seat, it doesn't sag all that much. Anyone know what I'm dealing with?
Old Jan 31, 2006 | 07:13 AM
noahrexion's Avatar
Yes you are probably dealing with your spare tire as thought of Although it feels nice and secure it can slide. This is a common complaint
Old Jan 31, 2006 | 07:31 AM
eric-the-red's Avatar
It's east to eliminate the tire as a possible problem, take it out and go for a drive. Could also be something loose, or worn shocks.
Old Jan 31, 2006 | 08:11 AM
MTL_4runner's Avatar
Ditto, mine does the same thing.....annoyning but I just live with it.
I would also take the spare out and just verify that is actually the issue.
Old Jan 31, 2006 | 08:15 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Not much to go on, but I would guess a bad, worn or loose shock. I had a similar noise at the front driver's side wheel and it went away after replacement of the shocks.
Old Jan 31, 2006 | 09:20 AM
Gerdo's Avatar
I have a coulple of thumps also. Mine is the rear seat, where it latches up. Fold down the rear seats and take for a test drive. I havent figured out a way to stop mine. I also haven't taken enough time to assess the situation yet. I'm thinking of splitting some hose and wrapping the attachment points. I just have to spent some time with it.
Old Jan 31, 2006 | 11:31 AM
DH6twinotter's Avatar
My jack under the rear seat used to thump around a little. Took me forever to figure out it was that until somebody here mensioned it. I thought it was part of my rear suspension too. I just extended my jack once it was in place to make it sit in there a bit better, and no more thumps!
Jeffreynmandy
Jul 18, 2015 08:26 AM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
