4wd Lo questions
Old Jan 16, 2006 | 08:58 AM
dfoxengr's Avatar
4wd Lo questions
what is the gear ratio for 4L on a 96 tacoma 3.4?
also, does the t-case act like a transmission of sorts just by switching between the three options?
Old Jan 16, 2006 | 02:37 PM
try these:
http://www.4x4wire.com/toyota/faq/parts/
most likely you transfer case reduces your gears by 2.66 (increase ratios compared to 4H)
normal gear ratio from 4H
http://www.marlincrawler.com/htm/transmission/8a.htm
gear ratio :1st 3.83, 2nd 2.74, 3rd 1.93, 4th 1.00 5th .83 Reverse 4.23
example of calculation of ratio (in this case for crawling)
http://www.off-road.com/toyota/tech/dualcase/
Old Apr 3, 2006 | 06:16 PM
dfoxengr's Avatar
can i swap the gear for just lo range?
Old Apr 3, 2006 | 06:33 PM
bob200587's Avatar
Yea, you can change the gears in you're T-case for low range, you wouldn't want to do it for the Hi. marlin crawler has T-case gears, I think they have a 4:1 and 4.7:1 ratios. It's EXPENSIVE tho. 399 for gears and then install.
Old Apr 4, 2006 | 04:50 AM
dfoxengr's Avatar
and since i probabaly am only 2.66 now this would increase my crawl raitio by a ton.
ill look into that. thanks.
Old Apr 4, 2006 | 11:29 AM
gravityfrog's Avatar
marlins only work in the older geared cases, not the new chain ones
Old Apr 4, 2006 | 01:44 PM
dfoxengr's Avatar
so then could i just change a sprocket and chain length and be done?
Old Apr 12, 2006 | 02:15 PM
dfoxengr's Avatar
sprocket swap??????????
DeathCougar
Apr 1, 2018 11:29 PM
makemusic116
Aug 2, 2015 04:40 AM
ripp96
Jul 31, 2015 11:14 AM
ripp96
Jul 25, 2015 02:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
