rubbing issue! PICS
Old Sep 25, 2008 | 09:44 AM
ty151's Avatar
rubbing issue! PICS
Hey, I have 265/75-16 BFG all-terrains on stock suspension on my 2000 2WD 4Runner...recently i got new wheels which are 16x8's and the rubbing issue has gotten worse. There is a little like pinch weld piece behind the plastic wheel well material that i had already trimmed for the tires and when i pull into a driveway or parking lot, it takes out little chunks of my tire and is like slicing through the tread.
So my question is if you guys think it will be okay to grind/cut that piece of metal off and out of the way?? Here is a picture..thanks in advance
Old Sep 25, 2008 | 09:47 AM
Matt16's Avatar
Hammer it flat.
Old Sep 25, 2008 | 09:50 AM
netwt12's Avatar
grind it off beat it with a hammer your choice.
Old Sep 25, 2008 | 09:55 AM
ty151's Avatar
yea i was thinking of just bending it back too...
if it still rubs, do you guys have any suggestions?
Old Sep 25, 2008 | 09:58 AM
1styota4X4's Avatar
LIFT IT!!!!
Old Sep 25, 2008 | 10:03 AM
ty151's Avatar
hahah easier said than done...thats for sure
Old Sep 25, 2008 | 10:14 AM
Rock Slide's Avatar
If it still rubs after you've pounded the metal flat (I don't think it will rub afterwards) and you do not want a lift, your only option is to go back to a stock tire size.
Old Sep 25, 2008 | 10:16 AM
ETRNL's Avatar
take a wooden bat and roll the pinch weld over. easy (very old) fix.
Old Sep 25, 2008 | 10:52 AM
ty151's Avatar
I will bend it flat and see what happens...it rubs just a little bit so i think bending it back will do the job. Thanks for the quick responses
Old Sep 25, 2008 | 10:54 AM
97ltd4x4's Avatar
Whatever you do make sure to get an anti-rust coating on that area.
Old Sep 25, 2008 | 11:05 AM
934rnr's Avatar
Bend it over is the easiest way.
If u cut it will.
1. open a big gap where it was pinch welded together and then rust like hell.
2. weaken the point where it was spot welded together.
unless your cutting it out and welding in new metal it's much easier.
Old Sep 26, 2008 | 08:02 AM
ty151's Avatar
Yea im just going to bend it over...
But whatr do you guys mean when you say an anti-rust coating? Like just rattle-can the area? Thanks
Old Sep 26, 2008 | 08:16 AM
Rock Slide's Avatar
Get a spray can of undercoating and spray that on the area. It will hold up better than just black spray paint.
Old Sep 26, 2008 | 08:24 AM
Cxrazy's Avatar
Also, take it in for an alignment if it still rubs and have them move that side forward a bit.
Old Sep 28, 2008 | 10:07 AM
brianyaklin's Avatar
i had the same problem when i went from the stock 28x8x15, that came on my truck, to 32x11.5x15. i just cut off the plastic and hammered the crap out of that metal piece. i still rub a little, but only when hitting a big bump or drop when my wheels are fully turned. if all else fails, get fender flares, it trim the fenders with a sawzall
Old Sep 29, 2008 | 02:58 PM
prospectator's Avatar
Since you went to an aftermarket wheel (you sold me your OEM wheels) you've changed the backspacing. The wheel your running probably has less backspacing, which increases the offset, resulting in the increased rubbing.
May 20, 2016 10:27 AM
highonpottery
7
Jul 18, 2015 02:48 PM
kvanzandt1
Jul 18, 2015 10:15 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
