Width or Height Limiting Factor on Stock 4Runner?
Old Oct 5, 2008 | 10:48 PM
MunkeyTX's Avatar
Howdy guys,
What is the major limiting factor on fitting tires on a stock 4Runner; is it the height or width of the tires that causes issues?
I know the recommended max size for 3rd gens is 265/75x16's (31.9x10.5); Interco makes their TrXus in a 255/85x16 (32.7x10.10); almost 1" taller and .5" narrower...and I like 'em!
So which is it? Do larger tires rub on the vertical axis on the wheelwell uppers, or on the horizontal on frame/wheelwell inners?
Old Oct 6, 2008 | 08:25 AM
crolison's Avatar
The simple answer, both. But you can run them if you dont mind trimming a little and using a bfh.
They will most likely rub on the pinch weld and the frame when fully turned, at least that is where mine rubbed at. And when you flex your gonna have to trim a part of your rear bumper.
If you don't mind trimming and using a hammer to clearecne some parts of the truck I would go for it.
Old Oct 11, 2008 | 09:20 AM
Ron Helmuth's Avatar
Both is the correct answer and crolison knows from experience.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
lledwod
Aug 30, 2016 01:03 PM
Nickdigg
Jul 7, 2015 06:04 AM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
