e-locker mod/pic request
Old Oct 1, 2008 | 05:54 PM
trd_4runnin11's Avatar
Does anyone have a picture of what wire I need to actually ground? I have everything set up and ready to go, just don't know which wire to ground. I know that I need to cut the blue/red wire and I know that I need to ground the side coming out of the harness....just don't know which harness. The HBOSS write-up that everyone seems to have used is no longer there so I just need to know which harness to cut the wire from and I'll be good. Thanks@
Old Oct 2, 2008 | 11:19 AM
eric-the-red's Avatar
If you're talking about the mod to use the locker in 2wd then you need to cut the wire and ground the end that comes from the 4wd ecu, the small black box in the driver side kick panel. The end of the wire that goes into the wiring harness can just be taped up.
Old Oct 2, 2008 | 03:17 PM
After a ton of searching las night, I was able to find the pin-out of the harness and a tiny picture to verify the correct harness. I got it done and it works except I noticed that my locker seems to engage much slower now then it used to. Is this typical of this mod, or is it because I was engaging the locker while driving on the street (under 5mph of course.)? I would have to idle forward very slow for about 20-30 feet before the RR DIFF LOCK light would go solid and I would hear it lock...
Old Oct 2, 2008 | 04:36 PM
Can't help you much with that question, ny locker is still sitting in my garage waiting to be installed.
Old Oct 2, 2008 | 04:38 PM
OSU4Runner's Avatar
Ya my locker takes a bit to engage. I usually have to creep foward about 50ft or so until it fully engages and the light becomes solid.
Old Oct 2, 2008 | 05:07 PM
rngrchad's Avatar
My 08 e-locker is stock. I haven't done the mod yet....will be doing it soon though. It locks in sometimes immmediately and sometimes it takes a long frigg'n time.
Old Oct 2, 2008 | 07:22 PM
Fo-runna's Avatar
My 98' is the same way... sometimes right away, sometimes takes a bit of work.
By the way, locker in 2wd is BAD ASS!!!!!
Old Oct 2, 2008 | 08:22 PM
Yukon's Avatar
turn from side to side slowly, but big enough turns to make the diff spin a bit, it will lock very quick.
Old Oct 2, 2008 | 10:19 PM
Elton's Avatar
yes like others have said does lock fast sometimes or slowly
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
jaretstuff
Oct 22, 2015 05:25 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
