Leaky Ball joint
Old Sep 30, 2008 | 04:58 PM
twitchee2's Avatar
Leaky Ball joint
Lately, i have been noticing some slight poping while back im backing up. Its just started to show up. I checked the steering ends and they are tight without any play. I went out and looked at things again and noticed the drivers side ball joint is leaking grease, so i jacked up the tire to check for play. There is not any in any direction. Is it anything i need to worry about? How hard is this to fix. The PO had the ball joint replaced warrenty or recall all i know is they were replaced back in july 206. Here are a couple pics, drivers side and passenger.
Driver
Pass
Old Sep 30, 2008 | 05:36 PM
crolison's Avatar
27 bucks a pop at toyota of dallas, you can rent a tool at autozone to get them out. thats what i am going to be doing sometime soon.
Old Sep 30, 2008 | 10:35 PM
twitchee2's Avatar
alright so it is shot and needs to be replaced. How long can i go without fixing it? Can it wait till January?
Old Oct 1, 2008 | 09:22 AM
GSGALLANT's Avatar
Just because the boot is leaking, doesn't necessarily mean that the balljoint is shot. It depends how long it's been leaking, whether or not there's still grease in there, whether dirt or water got in there, etc... If the joint is still tight, then you should be fine until January. What I'm getting at is that's not necessarily the source of your noise... it could be, but maybe not. See if you can get a grease gun (with a needle tip) to put some more grease in the joint, and see if the noise goes away. Might be a good test for you to do.
If the PO had balljoints replaced due to a recall, it was probably the lower balljoints... not the upper ones. I don't remember any upper balljoint recall on the 2002 4Runner. Good luck.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
