Interesting problem
Old Oct 4, 2008 | 05:09 PM
paxam's Avatar
Interesting problem
all
I have a 02 v6 s.c. when I am between 1800 and 3k light load it feels like the engine is cutting out for a second or two. I looked at the plugs and appear to be fine slightly black inside but the electrode is in good shape. the gap was at .040 to my supprise I regapped them to .031 -.032. also I cleaned the mass airflow sensor,air filter and throttle body. I am assuming it is a coil so I got a new one and swapped it out with each one but still it is dying. I check the resistance of all of the coils hot and cold primary winding and secondary all are with in .5 ohms... I am not getting any codes.
Also I drained the fuel and put fresh 93 + octaine boost in the tank.
any Ideas?
Old Oct 5, 2008 | 12:04 AM
KdF's Avatar
KdF
You seem convinced it's electrical.
Did you change the wires?
Also.......Fuel filter.
Ya, I know but they do not last forever.
Old Oct 5, 2008 | 06:44 AM
paxam's Avatar
the plug wires are 6 months old. NGK wires. fuel filter was done in Jan.
the electrical is a starting point since it is all controled by a computer.
Old Oct 5, 2008 | 08:07 AM
KdF's Avatar
KdF
My Dad's Ford years ago had the same symptoms and it turned out to be a bad plug wire. They can come out of the box bad.
Just sayin.........
Old Oct 5, 2008 | 12:00 PM
jeremy9allen's Avatar
How many miles on those plugs? They can look great but still miss under lite loads. Ford 4.6L are notorious for that. The plugs will look good and be in gap, but have an intermittant miss.
Old Oct 5, 2008 | 01:01 PM
paxam's Avatar
I think I found it..
a bad TPS I ohm out the orig and there is a spot that the resistance goes crazyfrom 400 Ohms to 1.2 then back to 420 ohms . I put my spare in and ran it so far no dying and my idle is back to 750 rpm's...
the plugs are less then a year and the wires 6 months or so.
Old Oct 5, 2008 | 05:46 PM
That would do it.
Old Oct 5, 2008 | 05:57 PM
j-man's Avatar
welcome to the world of bad tps sensors for the 02-04 tacomas, especially for those with forced induction. You will go thru them about every year or so. Last i checked, you couldnt buy them individually, you had to buy the whole darn throttle body, at least for my old 03 dbl cab i had. Good luck.
Old Oct 6, 2008 | 04:57 AM
DailyDrive's Avatar
That's exactly why any real tool box since the mid 90's should have an ODBII reader. This issue could have been found in under 3 minutes (literally).
Old Oct 6, 2008 | 07:42 AM
j-man's Avatar
no, actually the TPS starts to go bad before a code is ever thrown quite often. So the only real way to check is get a ohm reader and check it just like paxam did.
Old Oct 6, 2008 | 01:37 PM
DailyDrive's Avatar
see, you haven't even seen an ODBII reader. you might have seen ODBII code readers.
An ODBII reader will show values right on the screen that the ECU sees coming off the TPS. All you do is hook it up, slowly press the gas pedal and look at the values the TPS is sending back. This test actually takes about 10 seconds to perform, if not counting the time to hook up the ODBII reader.
Old Oct 6, 2008 | 02:38 PM
j-man's Avatar
shnizzle - i learn something new everyday...
Old Oct 6, 2008 | 04:12 PM
DailyDrive's Avatar
yeah, you could fix a Model T with a hammer. A carburetored car with a wrench set. But for the last 15 years the first tool out of the toolbox should have been an ODBII reader
Old Oct 8, 2008 | 12:56 AM
Ron Helmuth's Avatar
please to recommend an affordable one?
this is good info from all of you and I learned a lot. Is it necessary to spend around $100 for one? I welcome a brand and model number and value the opinions you guys have about these matters.
Old Oct 8, 2008 | 05:14 PM
DailyDrive's Avatar
Plenty of companies make ODBII readers, though I prefer Auterra with a handheld Palm. It will be a bit over $100, but doesn't mean you can't split that and share it with other. The economy is going down the so it's a good habit to get into anyway
Old Oct 10, 2008 | 04:18 PM
thank you
asked and answered I like these simple threads
I appreciate the recommendation
terminator
Jul 27, 2015 07:13 PM
Michael oaks
Jul 27, 2015 11:47 AM
RustBucket
Jul 24, 2015 04:46 AM
yourrealdad
Jul 21, 2015 11:13 AM
