285's with a body lift?
Old Nov 26, 2006 | 10:42 AM
HuskyRunner's Avatar
So, Ive got some plans for my 98 sr5, but need some help. Will 285/75/16's fit with only a body lift? If so, how big? 1" or2"? I realize that a body lift won't improve clearance or performance, but my tires are shot and I would like to go up to 285's now, and when finances allow get a Sonoran Steel system 1 lift. Also I know that if the tires will fit I'll need either spacers or new wheels, but what backspacing or spacer size? Thanks for your help.
Old Nov 26, 2006 | 10:52 AM
d0ubledown's Avatar
i think you can get away with an inch spacer, or 4.5 BS'd wheels. they will tuck nicely in the wells. stock is 4.3ish(i think? someone correct me). some run stockers with 285's, but i think theyre lifted. alot of steelies are about 3-3.75ish and stick out a bit more (which is what most run). a BL should also clear 285's...id go with a 1.5" just to be safe though. its an easy install. which 285's you thinking about going with? when ya get em on...lets go out wheelin! err..maybe not in this much snow..
and your wrong..BL WILL give clearance...for your tires
Old Nov 26, 2006 | 11:05 AM
Angus1's Avatar
Ive got an 04 taco I used front top load sring spacers 2" and cleared 285's with a little triming.
Old Nov 26, 2006 | 11:45 AM
Thanks for the quick reply Doubledown. Where would I begin to look for spacers in the lower mainland? I like the looks of the stock wheels, but if black steelies are cheaper... As for tires I'm leaning towards BFG A/T's. Yeah, too much snow right now...my truck is a white mound in the driveway. we've got about 10" since 6pm last night.
Old Nov 26, 2006 | 11:52 AM
d0ubledown's Avatar
talk to taran over at bigcountrycustoms.com. i just got a quote from him. 1.5" are on sale $95+ tax/pair and in stock. im sure you could get a good deal on 2 pair if you want to run all 4. i think 1" are a tiny bit more, but he'd have to get em for ya.
steelies are cheap. im sure if youre getting a set of bfg's you should be able to get a good deal on steelies all at one shop. if you can spring for steelies instead of spacers..do that. then you'd have your stockers for a backup set if you need.
and yes... a rear diff locked in 2WD with MT/R's on snow is NOT the ideal winter setup..but it sure is fun!
Old Nov 26, 2006 | 02:50 PM
waskillywabbit's Avatar
2" body lift will clear 285s for onroad use...you'll need more lift to wheel them and not rub like a fat woman in cordoroy pants.
Old Nov 28, 2006 | 05:02 PM
Would it rub only on the pinch weld? or would there have to be trimming and beating? It would only be temporary but...don't really want to destroy the truck or the tires.
Old Nov 28, 2006 | 05:21 PM
Without a body lift...you'll rub means you won't be able to turn.
Old Nov 29, 2006 | 03:12 AM
But WITH a body lift, where would it rub? It looks like a little pinch weld pounding should fix the majority of it, right?
Old Nov 29, 2006 | 03:49 AM
tacoma728's Avatar
IMO, six inches of lift is minimum for this size tire? My 33x12.50s still rub and i have a six inch lift. It is better to be safe than sorry.
Old Nov 29, 2006 | 03:50 AM
AH64ID's Avatar
Do you wheel the truck or just on the street?
A 2" BL allows for a 4" taller tire, so you should have no rubbing issues there, unless its on the aarm or frame.. A 1" BL allows for 2" bigger tires, so that should also work, and maybe just barely kiss at full turn and full stuff on the pinchweld.
A spacer or spring lift that isnt a bracket lift wont provide the clerance you need if you wheel the truck, you will need it and a BL to not rub. The BL is actually what provides the clearance, the springs/spacers just provide the added ride height and clearance under the frame...
Old Nov 29, 2006 | 03:58 AM
tacoma728's Avatar
I wheel it in the mud and muck and up hills and everywhere, lots of flexing and turning. I have 3" spacer + 3" body.
Old Nov 29, 2006 | 04:19 AM
KyleT's Avatar
You are most likey rubbing because you have a 12.5" wide tire. 285's are what, 11.4" wide? close to that though. width kills us vs. height.
Old Nov 29, 2006 | 04:57 AM
AH64ID's Avatar
You have to remember that when you flex you take out the 3" spacer lift since you compress to the stock location.... so the 3" BL is providing the clearance, and the width is what is killing you, and possibly your BS on your rims. A friend of mine has a 6" on his taco and the 33's rub the plasitc liner... nothing a little trimming wouldnt fix, but still, He could probally run a 35x10.50 and not touch anywhere.
Yeah, its amazing how much room you loose with wider tires..
Old Nov 29, 2006 | 07:30 AM
HUTCHSTACO's Avatar
width can be trouble, i don;t know but 3 inch body lift is a lot
Old Nov 29, 2006 | 07:33 AM
04 Rocko Taco's Avatar
its gotta be the width, on our trucks 3" will clear 33's for on road...off road you will rub a little "like a fat woman in courdory pants" (thanks Wabbit)
Old Nov 29, 2006 | 08:11 AM
HUTCHSTACO's Avatar
i like that, "like a fat woman in courdory pants", haha, its funny because its true
Old Nov 29, 2006 | 08:22 AM
tacoma728's Avatar
Yeah, next set i will go with might be 34x10.50. Although they are wider, i really like these tires and they do great off road. 33x12.50 BFG All Terrains.
Old Nov 29, 2006 | 02:57 PM
Excellent! Thank you for your help guys. It's settled - not done or paid for, but decided - 2" BL, wheels and 285's soon, and a Sonoran Steel kit when money allows. It's nice not to have to do it all at once. And it would look retarded to do the lift and BL first, then the tires. Now where's my wallet...funny, it's smoking and there is a hole where there used to be money. hmm.
Old Nov 30, 2006 | 03:40 AM
tacoma728's Avatar
yeah, looks like you have modifitis, he he. Good luck with the lift and tires when funds allow!
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
