Pro- comp coil spacers....good, bad?
Old Nov 2, 2006 | 02:28 PM
mattdon's Avatar
I want to give my truck a little more clearence for my tires and the ground. Would putting in 2.5 inch coil spacers be okay along with better shocks and springs. I figure this is better than a body lift and it actually lifts the frame and not just the body. Would or should I buy all the other stuff that goes into a "real" suspension lift?
http://www.4wheelonline.com/Products...roductID=87033
thanks in advance
Old Nov 3, 2006 | 10:46 AM
mattdon's Avatar
anyone?
Old Nov 3, 2006 | 11:33 AM
ButtPirate's Avatar
these poly spacers work great fo someone wanting just a little more height from their stock vehicle.
this one goes into your stock strut assembely, so you won't require longer shocks.
the procomp one is great because it's split into 2 pieces each side. one goes into the assembely and the other goes ontop of the whole thing. this eliminates a solid 2.5" spacer ontop of the strut that causes a lot of preload on the coil.
it's a good buy. go for it.
Old Nov 3, 2006 | 11:42 AM
SLC97SR5's Avatar
If you want the "real" suspension lift look at:
www.sonoransteel.com
They also have Daystar products which are very close to the ProComp stuff.
Old Nov 6, 2006 | 10:34 AM
mattdon's Avatar
For the price of the spacers it definately sounds like a good buy. Awesome thanks for the info guys!
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Sidherish
Aug 2, 2015 01:42 PM
Numberonedad6
Jul 30, 2015 07:10 PM
konah
Jul 30, 2015 02:08 PM
