2 flat tires. Tire Sizing Help guys! QUICK!
Old Nov 5, 2006 | 03:08 PM
04 Rocko Taco's Avatar
Exclamation 2 flat tires. Tire Sizing Help guys! QUICK!
Hey guys, today, not 1, but two falts, yes thats right 2!!!
So what I need from the YT community if the largest tires I can fit on an 04 Double Cab PreRunner Tacoma with no lift? Any chance I can fit 31's in there? Any ideas??? I gotta get em in the morning, help please guys!!!
~Chris
Old Nov 5, 2006 | 03:24 PM
Elton's Avatar
wow that sucks what size you running now ?
Old Nov 5, 2006 | 03:32 PM
265/70/16's.
I just measure, from thr ground up they are like (measured the spare, its the only full tread tire on the truck) 30 ish inches.... there is still almost 3" of room arond them in the wheel wells, there is no reason I shouldn't be able to fit 31's in there right?
What about 32's?
Whats the metric equivalent of a 31? 32? anything in between?
Old Nov 5, 2006 | 03:34 PM
waskillywabbit's Avatar
I just gotta say it...
tire size conversion newbie
Old Nov 5, 2006 | 03:49 PM
Elton's Avatar
265/75/16s are about 31.5''
Old Nov 5, 2006 | 03:52 PM
86SR522REEFI's Avatar
I searched, tire size calculator and found
https://www.yotatech.com/search.php?searchid=2283457
then went to this thread
https://www.yotatech.com/forums/show...ize+calculator
and found this
http://www.miata.net/garage/tirecalc.html
Old Nov 5, 2006 | 03:54 PM
but why cant you just get them repaired? sidewall damage? slashed? worn out anyways?
Old Nov 5, 2006 | 05:06 PM
MTL_4runner's Avatar
Originally Posted by 86SR522REEFI
That's the one I usually use too.
You should be able to fit 265/75R16s just fine (which are 31.6 ~ or about 32").
Old Nov 5, 2006 | 05:53 PM
yeah I got a good tire calculator, just thought I would ask the pro's. I think I am going to with the 265/75/16's, going with the Kuhmo Road Venture A/T's... What do you guys think?
Old Nov 5, 2006 | 06:32 PM
mpavolka's Avatar
BFG All-Terrains are spendy, but in my opinion they are the best all round tire.
Old Nov 5, 2006 | 08:08 PM
I cannot afford the BFG A/T's. $169.00 a tire. CANT do it...
Old Nov 5, 2006 | 08:45 PM
Texas Jim's Avatar
May be a dumb question here, but what is the tire load rating on your rig now? A? B? C? D? E? the heaver the load rating the or further down the alphabet E=10 ply tire it will be a noisy tire but will take a beating You may find some in a F ply. Don't know if that size will be avab. TJ.
Old Nov 5, 2006 | 09:08 PM
AH64ID's Avatar
OEM tires are a P tire, which is usually a B load range. C is about as tough as you need to go on these rigs, thou many of the common sizes like 285 are only available in D. The tires are stonger, but also much stiffer which is why OEM tires are P tires, they ride tons better than LT tires. 3/4 and 1 ton rigs come with Load Range E tires.
Old Nov 5, 2006 | 11:22 PM
TX-BLKRUNNER's Avatar
if your looking for cheap mud tires, wal-mart carries contintal super sports which wear pretty good, and are pretty aggressive offroad, the only down fall is that they are a bit noisy on the street, my buddy runs them on his frontier and he loves them, plus its wal-mart you can take anything back. yeah you should have no problems running 265 75 16
Old Nov 6, 2006 | 07:05 AM
Thanks guys! I did settle on the Kuhmo Road Venture A/T's in a 265/75/16 variety. $92.00 a tire, $235 for the pair mount balance (lifetime balance) and the orad hazard warranty. I'll let you know what I think.
Old Nov 6, 2006 | 07:07 AM
Elton's Avatar
sounds good
Old Nov 6, 2006 | 10:14 AM
amgraham's Avatar
I hope I misunderstood what you said but did you only get 2 tires? If so, don't run it in 4WD until you get the other 2 that match. Going up in size almost 2" on one end can put your drive train in quite a bind if you run it in 4WD like that. Again, hope I misunderstood...
EDIT - I forgot you had a prerunner so I guess it's a 2wd so you're good. You just don't want to run mismatched tires on a 4wd.
Old Nov 6, 2006 | 10:46 AM
yeah, theres really only about an inch of difference in the two tires, so only .5 inch between the ground and rim, and its a prerunner anyway, so I am good to go. I'm getting the other two in about a month. Tires were ALMOST worn out, but I had two flats, so went ahead and replaced those two, with the other two soon to come.
Jun 1, 2021 01:51 PM
Whatever123
Sep 30, 2015 12:12 AM
skoti89
Jul 8, 2015 12:05 AM
timmJ
Jul 7, 2015 02:01 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
