A340F Wiring
Old Nov 8, 2006 | 10:13 PM
Bill's Avatar
A340F Wiring
I've almost completed the tranny swap on my 86 pickup, but have hit a snag with the wiring.
I pulled out the stock A340F (it's a turbo pickup, so no A340H), and it has 5 connectors going to the tranny. The W56 I've put in only has 2 connectors(neither of them are the same as on the auto).
I'll try to get pictures ASAP, but until then, could someone give me at least an idea of which connectors would go to the neutral start switch, the reverse lights and the 4x4 light?
Old Nov 9, 2006 | 11:39 AM
toyotaoffroad91's Avatar
the 2 fat wires have to be jumped together or ran to the clutch nuetral safety switch...not sure on your year but it should be a black & black/white stripe. this tricks the ecu to think its always in nuetral. the reverse light---- on one wire out of the switch on the tranny splice to a good 12 volt source or directly to the battery the other wire out of the switch goes to the blue/red stripe wire. the 4x4 indicator light is not on that same harness. its on that trianglular shaped harness you should just beable to hook it back up the same way (if you have the 5 speed harness) the switch for the light is on the passannger side mounted on top on the transfer case....hope this helps also pull out your o/d light on the dash or just deal with it blinking.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
