New O2 Sensors and MPG dropped??
Old Nov 4, 2006 | 09:35 AM
vtruong1's Avatar
I just changed my front A/F Sensor (Cali Spec) and rear O2 sensor and my MPG dropped about 4mpg...what gives? Any ideas? Used OEM sensors, Tire Pressure is good, weather is getting colder but shouldn't effect MPG that much.
What do you guys think?
Old Nov 4, 2006 | 09:46 AM
CJM's Avatar
CJM
Disconnect the battery to let it reset.
Old Nov 4, 2006 | 10:09 AM
vtruong1's Avatar
I actually did that...and pulled the ECU fuse as well.
Old Nov 4, 2006 | 10:11 AM
CJM's Avatar
CJM
Huh, thats odd then-I dunno
Old Nov 4, 2006 | 11:34 AM
99SR5's Avatar
you might have tightned it too much or damaged it when you were installing it
Old Nov 4, 2006 | 01:03 PM
TX-BLKRUNNER's Avatar
man thats wierd, i just changed mine, and my milege jumped, there are no cel on are there? if so you mite put it on obd2 and see what it reads
Old Nov 4, 2006 | 01:13 PM
Elton's Avatar
anit that backwards ? thought the front was a o2 sensor or is it different for cali spec ?
Old Nov 4, 2006 | 01:28 PM
vtruong1's Avatar
Cali Spec has an A/F and O2 back. I had a CEL before thats why I changed the sensors out. I unpulgged the battery to reset the CEL, and been running really smooth ever since...but getting 14.xx MPG.
Old Nov 4, 2006 | 01:57 PM
MTL_4runner's Avatar
Where did the sensors come from? Are they OEM?
If you still had the old ones you could try swapping back one at a time and see if it is actually the sensors or just maybe that they switched to winter gas during your swap.
krimsonone
Sep 13, 2024 09:33 AM
Blamalam
Mar 12, 2022 07:34 AM
Tacoma1313
Aug 17, 2015 05:44 PM
coffey50
Jul 28, 2015 10:55 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
