Best Place to Pull 12V from?
Old Nov 16, 2006 | 08:09 AM
Greedy's Avatar
Hello,
I am re-wiring all my Split Second / URD boxes and need to find the best place to pull a solid 12V line from. I was having troubles with the boxes "malfunctioning" and found that I was not getting a full 12V to all of them. I need a good source to pull the power from and am also going to re-work all the grounds. Should I splice into a line that has a 15A-20A fuse or run a new line from the back of the fuse box and put an in-line fuse? Any recommendations?? Thanks.
Old Nov 16, 2006 | 08:18 AM
ErikJeanna's Avatar
Personally, I have no idea what a URD box is. However, if you're looking for a solid line, best bet is always to run a (fused) line straight to the battery.
Old Nov 16, 2006 | 08:24 AM
Greedy's Avatar
The URD box is a piggyback box that helps control fuel / timing / 02 sensors etc.. I can't pull directly from the battery as I need it to be switched so it turns off when the ignition is - otherwise they will be powered all the time and run down my battery..
Old Nov 16, 2006 | 08:28 AM
mastacox's Avatar
I got a auxillary fuse box from Summit that has ign-on sources with the use of a relay. I tapped the ign wire into the ECU's power, and then plugged the real power into the battery. This way, when the ign is on, the relay activates and therefore the FTC turns on too. This would be the most direct way of getting 12V to the FTC without having it be on all the time.
URD also suggests that you could tap the FTC straight into the ECU's power, but I wanted to have a separate fuse for the FTC.
Old Nov 16, 2006 | 08:43 AM
Greedy's Avatar
That is a great idea. I currently have an FTC, AIC x6 , ESC1, and MAF Clamp all spliced into the ECU power per the directions that came with them. It is proving to be to much to draw through that little 20 gauge wire though.
Besides adding another box to the back of my dash (gettin pretty crowded) - is there another line that would be as good to pull from?
Old Nov 16, 2006 | 08:56 AM
JHRRLD's Avatar
Do you remember which one you purchased? I'm having trouble finding one as you described on their website.
snap-on's Avatar
dont skimp on the wireing.
Pull a fused 10/12 gauge wire right from the battery.
for a more eleigent solution run that large 10ga wire to an axu fuse box and give each item your wireing up its own 5 amp fuse or whatever.
if you need accessory key'd power use a piggyback fuse and run the line from the piggyback to a relay to switch the large 12ga supply to your accessories.
Old Nov 16, 2006 | 09:07 AM
Greedy's Avatar
I was just about to ask the same thing. Went to summit and couldn't find one. All I could find was a 30 amp relay switch.
Old Nov 16, 2006 | 09:55 AM
mastacox's Avatar
It's the Painless Wiring "Cirkit Boss" ($59.95), with 4 ign-on circuits and 3 constant-on circuits.
Link:
http://store.summitracing.com/partde...5&autoview=sku
It was super easy to set up, and looks very professional when done. I would recommend taking all of the things you currently have spliced into the ECU's power, and moving them to the block, and then splice the "ign hot" wire on the Cirkit Boss into the ECU. Then you have 4 ign-hot sources coming straight from the battery (and they're only on when the ECU is on, but not when the key is in ACC, such as for listening to the radio). This also gives you 3 constant hot circuits for other accessories you want to power, such as lights or whatever. Also good, is it is "weatherproof" making it safe to set up under your hood.
I also added black plastic wire conduit around the wires in my engine bay, so you really can't even tell it is an aftermarket accessory. Looks totally OEM.
Old Nov 16, 2006 | 10:35 AM
JHRRLD's Avatar
Link:
Thanks!
Old Nov 16, 2006 | 03:22 PM
Greedy's Avatar
Ordered it and It will be here tommorow. Thanks for the help mastacox!
Old Nov 16, 2006 | 03:26 PM
mastacox's Avatar
Mmmm, overnight shipping
Old Nov 17, 2006 | 05:55 AM
JHRRLD's Avatar
Tuesday for me
shadowbirdie
Jul 21, 2015 10:38 PM
yourrealdad
Jul 21, 2015 11:13 AM
rushw
Jul 18, 2015 01:46 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
