Release pressure for fuel filter replacement help
Old Dec 2, 2006 | 07:30 PM
Tried to replace my fuel filter today. However, how hard I tried both of the bolts from the filter line did not budge at all. Yes, I did sprayed a lot of PB blaster, take off the gas cap, and use the crow wrench. Now the question is can I pull the EFI fuse in the fuse box and run it until the truck is dying to release all the built up pressure ? My truck is 00SR5 with 93K. Please help. Thanks
Old Dec 2, 2006 | 07:55 PM
KyleT's Avatar
taking the gas cap off usually lets the pressure out.
Old Dec 2, 2006 | 08:19 PM
UNR.Grad's Avatar
I didn't pull the fuse when I changed mine, just unscrewed the gas cap. But you can pull the fuse also, some do. Keep trying, they'll loosen.
Old Dec 4, 2006 | 10:29 PM
yota_krazy's Avatar
taking off the gas cap will only realease some of the pressure, it will likely spray a little bit and drip when your first break the fittings loose. Remember to not turn the key on with the lines off, it will be messy. I would try using a flare nut wrench, eat your wheaties too.
Old Dec 5, 2006 | 04:28 AM
MTL_4runner's Avatar
Keep spraying it every day for week with PB.....it will eventually loosen.
It helps alot to give the penetrant time to work.
Old Dec 5, 2006 | 09:01 AM
profuse007's Avatar
need to take off cap for siphonage to stop. I have never had to replace my filter but if it is inline filter, use a flare nut wrench to avoid stripping. For the filter that has banjo bolt, use impact wrench to break it loose.
Old Dec 5, 2006 | 01:36 PM
You can also try the tabasco route!
Here's the writeup anyway:
http://www.4runners.org/articles/fuelfilter/
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 8, 2015 12:05 AM
HRDC0R19
Jul 5, 2015 06:43 PM
