Wheels: 16x8 w/ 4.0 BS OK?
Old Nov 18, 2006 | 07:46 PM
marko3xl3's Avatar
Hey guys, I am just posting to get a little advice about wheels.
I am planning to sell my current OEM 16" alloys to a member here and get different wheels to replace them (obviously ). My dilemma is that the wheels I am wanting to buy (Pro-Comp 1069, see pic) comes in two variants of backspacing, 4.5 and 4.0.
My preference would be to get the 4.0" because I want to do the large Tundra upgrade (231mm) which would help me with fitting the larger calipers, and it would also give a truck a wider stance which is a good thing.
If anyone has any insight into this, I'd greatly appreciate the help.
Thanks,
Marko
Old Nov 18, 2006 | 07:52 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I have a set of these wheels w 4" backspacing and love them. I am running 305/70/16's on them and have no issues w rubbing. I am not sure about the tundra brake upgrade. Hope this helps in some way. If not, bump for ya
Old Nov 18, 2006 | 07:57 PM
marko3xl3's Avatar
That helps quite a lot actually. How much do your tires stick out past the fender flares, if at all?
Edit: Do you have any more pictures of those rims on your truck? Are you still using them? On another thread you said you had them on there for a while. If you did take them off, mind if I ask why? Thanks.
Old Nov 18, 2006 | 08:05 PM
4runner99's Avatar
i just bought new rims for my 3rd gen 4runner witha revtek 3 inch lift. the back spacing is 5.5. should i take them back and get 4.5 or is 5.5 ok?
Old Nov 18, 2006 | 08:12 PM
marko3xl3's Avatar
I would definitely return those rims. Stock backspacing is anywhere between 4.25 and 4.75 (not sure on the number) so you would be about an inch further in with the new rims which would probably not clear your calipers and most likely have your tire hit the upper a-arms. Why did you get such high backspacing in the first place?
Old Nov 18, 2006 | 08:18 PM
4runner99's Avatar
i had someone else get them for my while i was working. so its a perfect example of if you want it done right do it yourself!
Old Nov 18, 2006 | 08:49 PM
nc994run's Avatar
With the 305's, they barely stick outside the flares. I have since taken off the flares and herculined where they were. I still have the wheels on. I will try to find/ post a few pics of them.
Old Nov 19, 2006 | 06:41 AM
4runner99's Avatar
thanks
Old Nov 22, 2006 | 10:15 AM
willymoe's Avatar
Marko,
This wheel will work with the Tundra brakes. We sell them to the Tundra guys all the time. The backspacing is not the only factor in the fitment. The design and offset of the center also factors in. Here is a link to Centerline that shows the different styles of center and the relation to backspacing.
http://www.centerlinewheels.com/sub_wheel.php?mw_id=37
jason@wheelersoffroad.com
Old Nov 23, 2006 | 11:07 AM
marko3xl3's Avatar
Originally Posted by willymoe
Marko,
Wow, it couldn't get any better than this. I have looked on your site, and I was wondering if you're able to get me a shipping cost for 4 wheels to 95130 without me ordering?
Also, do you by any chance have pictures of 3rd gens with the black version of these?
Thanks for help!
Old Nov 27, 2006 | 12:49 PM
willymoe's Avatar
Marko,
Shipping appears to be around $45 for the set of 4 wheels. I could not find any pics of them installed in our collection.
Regards,
Jason
Old Nov 27, 2006 | 02:26 PM
rocket's Avatar
willymoe,
What is the backspacing on all your 16" wheels?
-rocket
Old Nov 27, 2006 | 02:41 PM
willymoe's Avatar
Rocket,
16" Alloy (black/polished) is 4.0"
16" Steel Type A is 4.5"
16" Steel Type B is 4.0"
Old Nov 27, 2006 | 03:26 PM
rocket's Avatar
thanks Will
marko, heres reply i found that you may find helpful...
Originally Posted by JHupp
I went with 16x8 with a 4" backspace, and they come to the edge of my fender flares on my '01, if I didnt have fender flares I would have only gone with the 4.5", daily driver here, and I didnt want to ruin the paint.
If i ever get new wheels, i plan on going with 4" or 3.75" BS. 4.5" is too close to being stock.
Old Nov 28, 2006 | 05:18 PM
4runner99's Avatar
I got my new tires and rims on my 3rd gen. the rims have 4 inch of BS with 287x75 around them. They don't rub at all. thanks everyone for the help!
TACODOC
03+ 4Runner/GX470, & 05+ Tacomas (Build-Up Section)
67
Nov 18, 2012 01:08 AM
Badfish740
Mar 19, 2012 07:20 AM
