Things to look at on a used supercharged 3.4 automatic
Old Jun 3, 2008 | 02:16 AM
skinnyhb's Avatar
im starting to look at a truck with 122,000 miles on it. its a 2000, 4wd, automatic 3.4. its on 33s. The original owner said that Toyota put the supercharger on at the factory very early in its life. Off hand, I'm concerned about the transmission and the longevity of the truck. Other things to look at/consider?
kenny
Old Jun 3, 2008 | 03:50 AM
mt_goat's Avatar
With that many miles the supercharger will need to be rebuilt so plan on some $$$ for that (about $700 IIRC). The first thing I'd check is the ATF condition. Then all the other fluids. Then drive it. I'd want to do a compression test before I bought it. While the plugs are out for the compression test scope the piston tops and cylinder walls for signs of damage and check the plugs for a lean condition.
BeMiceElf
Oct 10, 2015 09:40 PM
mengquis
Jul 13, 2015 10:39 AM
94whiterunner
Jul 12, 2015 07:15 PM
TokyoD23
Jul 12, 2015 06:01 AM
Cplmike
Jul 8, 2015 08:47 PM
