Overdrive
Old Jun 1, 2008 | 12:54 PM
Clemsonfan15's Avatar
Overdrive
What is overdrive? I've done some searching, but haven't gotten a really good answer. When should I drive with overdrive engaged? I have a V6 auto, if that makes any difference.
Old Jun 1, 2008 | 02:09 PM
Texas_Ace's Avatar
Overdrive is the 4th gear on most auto trannys. Some 5 speed auto tranny that is 5th gear.
I could get real technical but basically overdrive is the last gear (yes there are trannys with 2 overdrive gears) and it spins faster then the engine due to gearing.
You want to use Overdrive virtuall all the time except when you are first starting out on a real cold day or if you are towing/overloaded. Under towing conditions the using overdrive creates a lot of extra strain on the tranny and causes to to get haooter. Heat + Auto tranny = $$$$
Basically, it allows you to get better MPG and drive at highway speeds with low RPM's.
Old Jun 1, 2008 | 03:34 PM
Embfixer's Avatar
Gearing that allows the output shaft RPM to exceed the input RPM on a transmission. Ratio of drive in a gear box is 1 to 1. Over drive is 1 to < 1.1.
The point is lower engine (imput) RPM at higher (output) speeds....mostly for fuel econmy.
Old Jun 1, 2008 | 04:05 PM
corax's Avatar
Usually overdrive is automatically disabled by the ECU until everything's warm. Most just leave it on and ignore it. turn it off if you are towing or running up a long hill (to prevent gear "hunting"). you can also turn it off on long downhills to provide a little bit of engine braking and prevent overheating the brakes
Old Jun 1, 2008 | 05:37 PM
Thanks for all the answers.
This is just what I was looking for. I use it virtually all the time so I was doing what I should have been.
Thanks again for the replys.
Old Jun 2, 2008 | 09:58 AM
mkgarrison5's Avatar
when driving in the mtns of NC, Va and Tn, i always keep the OD off. it drives me nuts when the tranny is constantly shifting up and down..
Old Jun 2, 2008 | 11:45 AM
That's probably the most annoying thing about my 4runner. I'll be going up not even a semi-steep hill and it will jump about 500-100 rpm.
Old Jun 2, 2008 | 11:48 AM
Sloan's Avatar
yep everytime i go up a steep hill on the highway it sounds like my 4runner constipated and having trouble going to the bathroom.
Old Jun 2, 2008 | 12:15 PM
Texas_Ace's Avatar
LOL, that is great! If i had any more room in my sig it would go in there.
Liadrin
Apr 25, 2022 02:54 PM
chuckross1957
Jun 28, 2019 10:19 PM
crammit442
7
Nov 29, 2017 12:30 PM
rmill05
Sep 27, 2015 01:43 PM
keithporter83
Jul 24, 2015 07:37 AM
