Old Mar 30, 2016, 03:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Towing & Hauling Guides
Print Wikipost
Installing trailer light hook up wiring question.
Old May 12, 2008 | 09:20 PM
LuminoZ's Avatar
So as the title says, I'm going to be wiring the truck in my sig for trailer lights. I'm pretty confident that I figure out where to splice in for the kit that I have, but I'm concerned I need to up the AMPS on a fuse for the lights? Do I need to swap some fuses, or can I just plug and play?
Old May 13, 2008 | 05:39 AM
gpcollen1's Avatar
There shouldn't be any 'splicing' to do, it should be plug and play. Make sure you Install it on the correct side of the vehicle - read the directions. I got mine from etrailer.
Old May 13, 2008 | 05:42 AM
zlathim's Avatar
Good post.
Get the plug and play version. Don't worry about changing fuses, as long as the trailer does not have any shorts, you will be good.
Old May 13, 2008 | 06:06 AM
Mojo_Risin's Avatar
did your trailer light kits come with a 4 pin flat connector? I have a 6 pin round trailer and finding a 4 pin to 6 adapter is difficult and I don't see any toyota kits that come with anything but a 4 pin flat.
Old May 13, 2008 | 08:42 AM
Maj's Avatar
Maj
First off, installing a fuse rated higher than the original is always a bad idea. The fuse rating is determined by the wire size (which was calcualated by the factory for the load of everything on the circuit). So putting a larger fuse in will smoke the wire.
The good news is that splicing into your factory wires will be fine. The extra capacity is built-in the wiring (and fuse) and pretty much all other vehicles built in the last 20 years.
Old May 13, 2008 | 04:17 PM
LuminoZ's Avatar
I didn't buy any toy specific kit, just one from napa for 20 bucks. If there is a toyota vehicle specific one, how is it different than the one I have where I just splice into the correct wires?
Old May 13, 2008 | 07:20 PM
Froggy93's Avatar
As long as you splice into the right wires, it doesn't matter. The plug and play are much easier to install but not necessary. You do not need to up the amp rating on the fuse. unless you have a short or something as Maj said you shouldn't have a problem.
Old May 14, 2008 | 06:46 AM
Mojo_Risin's Avatar
The Toyota specific one just plugs and plays... Here's a PDF of instructions for the Tacoma version (might help even with your splicing)
http://www.draw-tite.net/pdf/N118379.pdf
here's the tacoma version on EBAY That looks similar to the one i got.
John
Old May 14, 2008 | 07:46 AM
dropzone's Avatar
Fossilized
so with a 6 pin trailer connection that usually means that your trailer is equipped with brakes so you would also need a brake controller. Especially if the trailer is rated to tow above a certain weight (for example 3500 lbs or is tandem axle) .
differences between 4 wire and 6 wire diagrams:
http://www.accessconnect.com/trailer_wiring_diagram.htm
wiring a controller in is not too hard and being able to manually apply a little pressure on the trailer brakes manually makes towing easy.
Old May 14, 2008 | 05:48 PM
Mojo_Risin's Avatar
Actually there are no brakes on it - it's a small pop-up camper.
John
Old May 14, 2008 | 05:54 PM
dropzone's Avatar
Fossilized
John
OK, one wire can be used to activate a electric brakes (if trailer is equiped) and the other wire can be used to charge the battery on your trailer,
Old May 14, 2008 | 05:58 PM
GenXr's Avatar
Thanks for the tip on the etrailer site. $35 bucks for a plug and play harness is awesome.
Old May 15, 2008 | 06:08 AM
gpcollen1's Avatar
Genxr - just make sure you install on the correct side or you will have to swap/splice the wires afterward, unless you feel like taking it apart again, like I did not.
Old May 13, 2013 | 05:53 PM
nuttynu's Avatar
Is the plug n play located in the taillight ?
On a 93 pickup ?
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
bryan34w
Jul 6, 2015 05:53 PM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
