SRS light...Possible New problem????
Old May 20, 2008 | 10:35 PM
slayenemy's Avatar
So i posted on here about a week ago about my SRS light on my dash all this sudden staying on. I have not been able to pull the codes yet, cause im broke till my next paycheck, but i noticed something weird the other day....My horn didn't work after some jerk completely cut me off, and it did the day before the light came on. On another note, I was driving today and i all this sudden heard a loud WA-POP inside my dash, it sounded like it was under the cd player console. I cheked it out real good and didn't see anything abnormal. opened the hood and didn't notice anything. Whats weird is i was driving on a very smooth road. Any ideas? airbag? thanks!!!
Old May 21, 2008 | 02:28 AM
HAVOC's Avatar
Horn not working and SRS light leads me to believe the "spiral cable" is no good.
What kind of vehicle are we talking about?
Old May 21, 2008 | 06:45 PM
slayenemy's Avatar
Its a 2001 Toyota Taco 4x4 Sr5 Auto tranny. Any idea what that pop noise in my dash was? Any help is appreciated. Thanks!!!!
Old May 21, 2008 | 06:59 PM
HAVOC's Avatar
I never heard a "spiral cable" pop, so I dont think that's it.
Where in the dash did you hear it? Any other problems besides SRS?
Did you pull the codes?
Old May 21, 2008 | 09:28 PM
slayenemy's Avatar
The pop i heard came from somehwere behind the dashboard, sounded like it was in the middle where the A/C console and Cd player are. There is no other problems besides that pop i heard, and the horn not working. I won't have the money to take er in to toyota for a couple more weeks. and i dont know anything about pulling codes myself. Thanks for tryin to help man!
Old May 22, 2008 | 02:28 AM
HAVOC's Avatar
PRE−CHECK
1. SRS WARNING LIGHT CHECK
(a) Turn the ignition switch to the ACC or ON position and
check that the SRS warning light lights up.
(b) Check that the SRS warning light goes out after approx.
6 seconds.
HINT:
When the ignition switch is at ACC or ON and the SRS
warning light remains on or flashes, the airbag sensor assembly
has detected a malfunction code.
If, after approx. 6 seconds have elapsed, the SRS warning
light sometimes lights up or the SRS warning light
lights up even when the ignition switch is OFF, a short in
the SRS warning light circuit can be considered likely.
Proceed to ”SRS warning light circuit malfunction” on
page DI−471 and DI−473.
2. DTC CHECK (Using diagnosis check wire)
(A) Present troubles codes:
Output the DTC.
(1) Turn the ignition switch to the ACC or ON position
and wait for approx. 20 seconds.
(2) Using SST, connect terminals Tc and E1 of the
DLC1.
(B) Past troubles codes:
Output the DTC.
(1) Using service wire, connect terminals Tc and E1 of
the DLC1.
(2) Turn the ignition switch to the ACC or ON position
In section A-2 the SST is just a jumper wire. So is the "service wire".
Old May 22, 2008 | 05:03 AM
gilby4runner's Avatar
Cant you go to Auto Zone and have codes pulled for free?
Old May 22, 2008 | 10:42 AM
slayenemy's Avatar
No, I asked they said, I could buy the tester and do it myself, then return it. So kinda but again i run into that prob of i don't know how to do it. Ugh!
Old May 22, 2008 | 06:24 PM
HAVOC's Avatar
Check my last post, all you need is a jumper wire. Alot cheaper than a scan tool.
SubiKing
Aug 21, 2021 03:57 AM
icentropy
Sep 16, 2020 02:47 PM
theking11863
Mar 19, 2016 09:36 PM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
