No reverse lights
Old May 28, 2008 | 11:38 AM
Motorcycle RN's Avatar
No reverse lights
I have a 1997 Taco with 222k miles on it. The reverse lights quit working recently. I checked the fuses and they're ok. It's a 5 speed manual. I found a switch on the passenger side of the trans and checked it with a continuity tester with the key on and the shifter in reverse. There was no electricity to either wire. Anyone have any ideas?
Old Nov 18, 2010 | 06:59 AM
Anyone??? Bueller???
Old Nov 18, 2010 | 08:08 AM
Gerdo's Avatar
I have a problem with my back-up lights not working also. I haven't climbed under to check it out yet.
Not so sound like an a$$ but, i assume that when you are checking for voltage you have the key turned on?
In my case, I'm guessing that the trans switch is bad. It started to be intermittent. I could jiggle the shifter and it would flash on/off.
After clicking on the "tags" and "reverse" below I got some trouble shooting ideas.
Pull the wires off the switch, insert a wire connecting the two wires together, start the vehicle (it can be in neutral now) and look at your lights. This eliminates the switch. If they light then it's a bad switch OR what ever pushes on the switch inside isn't touching it any more. Next step is to pull the switch out and check continuity with a meter.
Old Nov 29, 2010 | 07:57 PM
Ron Helmuth's Avatar
It's most likely the switch itself- I have been told they fail pretty frequently. Use a discount place like Toyota Parts Zone to verify a fitment against your VIN number.
Old Dec 1, 2010 | 12:50 PM
ALLDATAdiy INFO's Avatar
FormerVendor
Check your Back-Up Lamp Relay and see if you have power there.
Old Dec 7, 2010 | 09:55 AM
etc.'s Avatar
Yes this
Old Dec 7, 2010 | 10:24 AM
Swimmerboy2112's Avatar
I'm agreeing in saying its the switch, same thing happened to my Tiburon.
Old Dec 7, 2010 | 10:34 AM
TheDurk's Avatar
Really good info in this thread, including pictures. Part you need is 84210-12040 at toyotapartszone ($27.60).
https://www.yotatech.com/forums/f2/b...l-trans-92335/
AkitaDog
Sep 1, 2015 08:05 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
