Anyone else breaking CVs with Toytech OME 3" Lift
Old May 12, 2008 | 05:45 PM
Goin's Avatar
2 times "really wheeling" and 2 broken CV's. The first CV breakage I chalked up to driver error and old CV's. See explaination here https://www.yotatech.com/forums/f2/w...-break-138059/ . I now have new CV's installed and a lesson learned from last experience (no hard turns with heavy flex/torque).
I was out wheeling this weekend and I really was not doing anything I feel is extreme compared to some on this board, when POP. This time I was tracking straight up a slightly slick hill with slick roots up it and was experimenting with the different 4wd modes. It broke on my 3rd or 4th pass. Anyways, I didn't take pictures, but it really was not a very tough obstacle and I can't see where I was putting more than accepible levels of strain on the truck.
I have the Toytech OME3 Run lift http://www.toyteclifts.com/images/pr...Runner-640.jpg . This is 881 up front and a small (3/4") top plate spacer. I am thinking the small top plate spacers might have to go, yet I really like the look of the level lift. Is any one else wheeling the Toytech OME3 Run Lift hard and not breaking CV's?
After the first break I installed lifetime guaranteed CV's so it really isn't a huge deal, but if I wanted to fix something after everytime wheeling, I would drive a jeep.
Old May 12, 2008 | 06:08 PM
BajaRunner's Avatar
Ugh, that does suck.
3" is max in the lift department, I'd drop down to 2" and add a 1" body lift.
Theres a possibility the CV's you replaced the OEM ones are not up to standard.
Old May 12, 2008 | 06:14 PM
Godzilla's Avatar
Also what shocks are you running? There was alot of concern of adding a top out if running the OME comforts and the tundra coils because of over extension. Though you have OME the same issue may apply.
Old May 12, 2008 | 06:16 PM
Goin's Avatar
Full Relevant Specs:
Tokico Trekmaster Shocks
Toytech OME3 Run Lift (881+ 3/4" top plate spacer/890)
Toytech 1" Diff Drop
Toytech Drop Bracket
285/75/16 MTZ on LC wheels
New Budbuilt skid and belly pan + 99+ fat lip bumper adding weight to front end
The aftermarket CV's were purchased at Advanced Auto
Old May 12, 2008 | 06:37 PM
BigBallsMcFalls's Avatar
2 inches is max in the lift dept with cv's
anything taller will snap them all the time...and 2 inches is still stretching it
SC4runner has it right. 2 inch and 1 inch body
or solid front axle and ditch the stock setup entirely
Old May 12, 2008 | 06:41 PM
4Crawler's Avatar
Adding a front diff. drop spacer (if not already doing so) may help in this situation:
- http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Might just lower the CV joint angles that little bit to make them last longer.
Old May 12, 2008 | 06:50 PM
Vermejo's Avatar
Don’t feel bad, it happens. I don’t attribute my breakage to my set-up, a widely popular one with many users to back it. It seems that under certain conditions the angle becomes too severe and pressure too great to give any further. Sooner or later they all die.
Old May 12, 2008 | 07:02 PM
Dare44's Avatar
hmm, i have put mine thro its paces pretty well and havent had this happen, knock on wood, andi have the top out spacers and same lift. i dont understand that
Edit: Broke it yesterday dam it!!!!!!!!
Old May 12, 2008 | 07:10 PM
Goin's Avatar
4Crawler, I installed the Toytech 1" Diff Drop.
I thought the tundra coil and BamaChem Top spacer that most run so successfully is fairly equivalent in lift characteristics to the 881 and 3/4" spacer? It would just be ride quality that is different.
Old May 12, 2008 | 07:18 PM
Goin's Avatar
Good first hand experience, how long have you had the lift and have you tested the lift/spacer setup? Thanks Dare,
Anyone else?
Old May 12, 2008 | 08:29 PM
Jdizzydub's Avatar
Anyone else?
Running that same set-up for almost 2years and I bang it around a bit, i'd consider myself a beginner 4wheeler. But I do get out there and challenge my rig. The only cv related issue i've had was busting a seal/clamp that i caught early and put a hose clamp on there. It's been there ever since. I gues I've been fortunate...I will soon be looking/saving for spare cv's just incase.
My sister lives in ARnold!!!
Old May 12, 2008 | 08:58 PM
1999runner's Avatar
On my 99 3" revetek spacer kit shock like hell. It was at least a 1" higher in the front with 890 coils in the back. 2" or your cvs hate you they dont like it. oh by the way i had the diff drop.
Old May 12, 2008 | 08:59 PM
4Runner202020's Avatar
I have 3.5 in of front lift and have yet to break a cv. But back when I did have the same set up as you I broke them all the time. Weird I think...
Old May 12, 2008 | 09:09 PM
Albuquerque Jim's Avatar
Welcome to the dark side
The 3/4" topout is the likely culprit; topout spacers break things, too much droop.
Old May 13, 2008 | 05:47 AM
what will bust them is highway speeds and heat, heavy tires and severe angles
combined
if all you do is crawl they might last
Old May 13, 2008 | 06:11 AM
Ohio4R's Avatar
Just take out your top-out spacers and see if that works, and i would recommend getting the half-shafts from toyota, the ones from other places aren't built as good as OEM.
Old May 13, 2008 | 06:54 AM
mt_goat's Avatar
Maybe you can use thicker upper bump stops or spacers on the bump stops to limit the CV angles. That way you keep the lift but limit the droop. I think if you have lockers droop is over-rated anyway. I am just about at full droop sitting flat on the ground. Its a sacrafice I made to help with CV life.
Old May 13, 2008 | 07:32 AM
hross14's Avatar
Yeah, I dont understand what is happening--i am running 35's open up front, 2.5" SS #7 and i have yet to break a front CV (I expect it to happen though just not all the time). Maybe there is something about this combo that just isnt right?
Old May 13, 2008 | 08:30 AM
dirtoyboy's Avatar
That could be a part of the problem
Old May 13, 2008 | 08:44 AM
Maj's Avatar
Maj
I concur with the others that the top out spacer is the prime suspect. The CVs weren't designed to go beyond the factory droop. Steve sold limiting straps for the front at one time, dunno if he still does. That would allow you to keep the spacer and still limit to factory droop.
