Rough running (CEL) after engine bay clean
Old Nov 22, 2007 | 05:26 AM
PAULUNM's Avatar
Hello all,
My '96 Runner got a good engine bay clean yesterday (looks brand new!) but on the way home it started running on 5 cyls and the Check Engine Light came on- it actually flashed for a little while, which I have heard is REALLY bad... I got it home, let it sit for a few hours- started it, and it runs on all 6 cyls, but still rough. I am hoping something got wet (electrical), and it is drying out... Any other ideas? I will get the codes read at Autozone when they open...
Thanks!
Old Nov 22, 2007 | 05:54 AM
MTL_4runner's Avatar
Need a code before we can help you with that one.
This is a 3.4L motor I assume?
Old Nov 22, 2007 | 06:14 AM
PAULUNM's Avatar
Yes, 3.4L 1996. I will get the codes read ASAP (who's open on TGiving....)
Old Nov 22, 2007 | 06:23 AM
KdF's Avatar
KdF
Just pull the plug wires and dry out the channels, bet one is full of water.
use a blower if ya have one or a screwdriver with a dry rag.
Old Nov 22, 2007 | 11:54 AM
PAULUNM's Avatar
There is some water in there- I'm letting them dry out now. I also noticed that the plug wires don't "snap" onto the plugs- they come off way too easy. I'm going to replace the wires and plugs when NAPA opens up. I haven't taken the coilpacks off the passenger side of the motor- is there a spark plug connnector that connects the coilpack to the plug? I would like to replace those as well.
Thanks all!
Old Nov 22, 2007 | 01:21 PM
Sounds like you've found your issue.
Old Nov 22, 2007 | 01:33 PM
PAULUNM's Avatar
I will keep you all posted- hopefully that's all it is! What about the coilpack to plug connectors (Pass side), should those be replaced along with the other plug wires (drivers side)?
Old Nov 22, 2007 | 02:33 PM
KdF's Avatar
KdF
They don`t come with the wires.Those are expensive to replace.
I don`t have a firm snap on mine either, Just as long as its flush with the cover, should be just fine.
I use the NGK BKR5EKB11 plugs all the way around on mine. The dual electrode ones.
Old Nov 22, 2007 | 03:24 PM
Prophet_MX's Avatar
Also make sure there are no cracks in the destributor cap. I had a truck that had the cap crack when it got hit with some cold water when I was playing in puddles. The firing order was screwed up from it and the truck ran really rough.
Old Nov 22, 2007 | 05:18 PM
The 3.4L has a distributorLESS ignition.
Old Nov 22, 2007 | 06:34 PM
Texas_Ace's Avatar
I have also been having a rough idle since it got cold here for some reason i don't know. When i am at a stop light i have to give it a little gas to keep the RPM's above 500. If i let go it doesn't die but hivers at about 500 where it is pretty rough.
Old Nov 22, 2007 | 06:44 PM
4runnerguy's Avatar
boo u guys go to get the triple electrode ones
Old Nov 22, 2007 | 07:00 PM
Texas_Ace's Avatar
You lost me there...
Old Nov 22, 2007 | 07:25 PM
d0ubledown's Avatar
[OT]
out of curiosity...how did you clean your engine? with a pressure washer? any cleaning agent with it?
my bay is way long overdue for a wash..i just want the safest, least destructive way to thoroughly clean it.
[/OT]
Old Nov 22, 2007 | 07:29 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Not tryin to start an agument or anything but spend a couple extra bucks and get the parts from Toyota. Stock Toyota plugs and wires are just fine and they do what they are made to do, Toyota would make 'em if they didnt work, also they will fit better than napa/kragen so you wont have the water leakage problems that you did. If you dont want to pay the extra dough then just think of what you'd be drivin if your entire truck was made from Napa parts. Just my $.02.
Old Nov 23, 2007 | 03:56 PM
PAULUNM's Avatar
I replaced the plugs and wires (from Toyota), and it runs great now! Thanks all!!
Old Nov 23, 2007 | 04:18 PM
toylocost's Avatar
Congratulations!
Old Nov 23, 2007 | 04:23 PM
twitchee2's Avatar
replaced the plugs EXACT same thing happened to me. something got wet.
live4soccer7
Sep 3, 2015 12:29 PM
puffin04
Jul 10, 2015 09:17 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
2wdtundra
Jun 18, 2015 05:19 AM
