Frustrated, Need Some Help Here.please
Old Nov 26, 2007 | 11:03 AM
H82BL8's Avatar
I had a CEL come on, on my 97 4Runner (3.4 V-6) and took it to autozone and they gave me the printout with the code P0133. Looked like an O2 sensor, vehicle started running rough and hesitating/missing. I replaced the O2 sensor with one from Toyota and vehicle was still missing. I then replaced the plugs and vehicle still missed. I then replaced plug wire (Borg/Warner) and vehicle is still missing. Any help at all would be greatly appreciated.
Old Nov 26, 2007 | 11:05 AM
gilby4runner's Avatar
Did you reset the computer after you replaced everything? Pull the EFI fuse for a minute or two and try it again.
Old Nov 26, 2007 | 11:10 AM
H82BL8's Avatar
I did reset it by pulling the EFI fuse and then disconnected the positive battery terminal. It cleared the code but then it came right back and was blinking.
Old Nov 26, 2007 | 11:16 AM
epage46's Avatar
Which O2 sensor did you replace? If I remember right there are two.
Old Nov 26, 2007 | 11:22 AM
MTL_4runner's Avatar
Did you recheck the code again to make sure it was the same code and not a different one?
Also make sure to use only NGK or Denso (OEM) replacement parts, I can't stress this enough!
Get the code checked again if you haven't already.
Old Nov 26, 2007 | 11:26 AM
hross14's Avatar
Besides the stuff already mentioed--what about cleaning the maf--checking the TPS?
Old Nov 26, 2007 | 12:02 PM
tampabayota's Avatar
x2 on the tps^^^^^^
Old Nov 26, 2007 | 01:25 PM
H82BL8's Avatar
Took 4Runner to shop, now have a $311 tab for 2 coil packs and labor. They say it's fixed. I guess we'll see. Thank you all for your input.
Obmi
Oct 4, 2015 11:30 AM
VT2LAB
Sep 10, 2015 09:36 AM
128keaton
Sep 3, 2015 05:09 PM
digdug40
Aug 28, 2015 02:24 PM
izzmee
Aug 17, 2015 10:20 AM
