99' and 03' Tacoma front spindle the same?
Old Oct 18, 2010 | 06:52 PM
CrunchyTaco's Avatar
Switching lift kit over to new truck today and the spacer the came with my all-pro uca's is stuck in the spindle of my old truck (and no, I am an idiot and did not use anti-seize). I hammered on it for quite a while without a budge. I have been spraying penetrating oil on it for a week now.
Can I just take the caliper and rotor off and disconnect the spindle from the cv and bottom part and just switch it over with the spindle on my 03? They look the same but I was not sure about exact specs. Are the brakes the same also?
Thanks for any help!
Old Oct 18, 2010 | 06:55 PM
A little more info on my trucks; both extended cab,4x4, 5spd, v6's with ADD.
Old Oct 18, 2010 | 08:43 PM
scuba's Avatar
The spindle assembly is the same and will bolt in. Does each have ABS?
Old Oct 18, 2010 | 10:03 PM
DeathCougar's Avatar
The major difference you will run into is ABS, as scuba mentioned. 03 Tacomas have ABS, 99 Tacomas had an option for ABS but not all came with ABS.
Old Oct 18, 2010 | 10:18 PM
scuba's Avatar
Yep. Though, I'm not sure if the non ABS spindles will have provisions the ABS. Think you might have to switch out the speed sensor rotor for the spacer if one has abs and the other doesn't.
http://www.ncttora.com/FSM/2003/Repa...4wdpr/comp.pdf
OP, you sure you took the snap ring off of that uniball adapter?
Old Oct 19, 2010 | 06:05 AM
LOL, yeah I am positive. I could see that happening though!
My 99' doesn't have ABS so I will have to see if everything will switch and if there is a mount on the 99' spindle for the ABS.
Since this is starting to sound more and more like a PITA to swap spindles, do any of you have any creative ways to remove the uniball adapter w/o ruining it or the spindle? Heat maybe?
Old Oct 19, 2010 | 06:07 AM
And thanks for that diagram Scuba!
Old Oct 19, 2010 | 07:15 AM
If you are switching '03 spindles on your truck, just disregard the ABS. It will work just fine. If you happen to have ABS, then viola it will plug in!
Old Oct 19, 2010 | 09:18 AM
DeathCougar,
You have me a little confused now. I am switching my 99' spindles that have the adapter in them to my 03'. The spindles on the 03' have to go to the 99' so I can sell the truck. The 99' does not have ABS, the 03' does. Can you explain a little more about your above post?
Old Oct 19, 2010 | 09:29 AM
Ok my bad, thought you were going the other direction.
If you swapped 03 spindles onto a 99, you could merely disregard the ABS. Since you are swapping Non-ABS spindles from your 99 onto an '03, you are going to lose ABS.
Old Oct 19, 2010 | 12:10 PM
I have never had ABS anyway but won't that screw with the computer?
Thanks for the help. Should have known better when I installed the lift. 1 little dollar tube of anti-seize and I wouldn't be going thru all this b.s.!
Flying91
45
Apr 11, 2024 04:39 PM
94whiterunner
Jul 12, 2015 07:15 PM
TokyoD23
Jul 12, 2015 06:01 AM
Poncho0206
Jul 10, 2015 06:21 PM
akaphilly
Jul 9, 2015 02:18 PM
