Automatic 4runner transmission problem
Old Nov 26, 2010 | 04:02 PM
fireman33's Avatar
Hey guys, im new to this forum here and i really need help. I have been a member on ttora for a few years and ive searched the internet for a while without success.
V6 auto tranny started acting up 2 months ago. When i pull up to a stop sign the truck will not downshift to 1st gear on its own. I have to manually shift it in 1st in order to be able to take off again. If i dont do that and just leave it in Drive it will try to take off in 2nd gear which doesnt work because there is not enough power.
I flushed the transmission fluid and put in a new tranny filter but it did not help with my problem.
So when im at a stop and i put it in 1st then back in drive everything works like it should....the truck upshifts normally from 1st gear right up to overdrive...
Help me someone lol.
Old Nov 26, 2010 | 07:11 PM
J2F42C's Avatar
Any CELs?
Could be a solenoid (#1)that is problematic but is not throwing a code.
Old Nov 27, 2010 | 05:01 AM
fireman33's Avatar
There was a code about a month ago while i was on my way home...and i have a scanner and was going to check what it was...but before i got home the code disapeared by itself lol...I think im gonna go ahead today and test the solenoids...i think there is 3 of them...which one is solenoid #1 ? is it the one closer to the rear of the truck ?
Old Nov 27, 2010 | 06:10 AM
phildelfino's Avatar
Parts.
http://www.bulkpart.com/Merchant2/me...e=A340solenoid
Manuals. 1st post.
https://www.yotatech.com/forums/f128...-years-156128/
Good Info on everything Toyota.
http://pirate4x4.com/forum/showthread.php?t=775780
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old Nov 27, 2010 | 06:58 AM
fireman33's Avatar
There is a lot of info on that hehe thanks.
Old Nov 28, 2010 | 04:16 AM
fireman33's Avatar
tested the solenoid last night and #1 and #2 are shot....the ohm reading is through the roof...is this what i need
http://cgi.ebay.com/ebaymotors/97420...Q5fAccessories
Old Nov 28, 2010 | 05:14 AM
J2F42C's Avatar
I think so, but with different manufacturers using the same transmission, they may be different.
Given they look like a legit store, call the 1 800 # to verify. If the link is not the correct solenoid kit, I'm sure these guys can get you the right one.
Let us know how it turns out....
Old Dec 4, 2010 | 10:20 AM
fireman33's Avatar
Allright here is the update guys...i replace shift solenoid #1 and #2 and the 4runner is back on the road and it shifts really good.
Thanks everyone for the help.
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
DuckFan
11
Jun 18, 2002 11:56 PM
