Limited flare/plastics removal
Old Oct 18, 2010 | 09:31 AM
vegaskurt's Avatar
I finally pulled the trigger and tore off all the plastics. Both driver side panels were driving me crazy cause they would "flap" when I was on the freeway.
Anyways, for a roll on job I am pretty happy. I used durabak after reading reviews of how people with 80 series cruisers did it. Front bumper needs to be trimmed up a tad and rear bumper is being trashed. I'm gonna start working on a new one this weekend.
Before
Removal and Tape
Lots of sanding.
Holes filled with metal tape.
Time for the durabak
2 coats later
Done. (front bumper needs a little trim now)
Old Oct 18, 2010 | 10:06 AM
4ever4running's Avatar
Nice work! That came out great! I am considering doing something similar to my truck, I just don't know how the black liner will look on a white truck...
Old Oct 18, 2010 | 10:27 AM
vegaskurt's Avatar
I think you would be ok with black. Grey might be a better option... The link below is of a white 80 series with durabak on it.
http://markkuz.com/PhotoAlbums/Cruiser-09/
Old Oct 18, 2010 | 10:28 AM
DirtyOregonKid's Avatar
That looks great, I've been thinking about doing something similar. I think that would look sick on your runner 4Ever.
Old Oct 18, 2010 | 11:59 AM
Yeah the more I look at it, the more I like it. I also recently picked up a scooped hood on Craigslist and I am thinking about doing that with Herculiner, Durabak or another similar product. I think it would look pretty sweet on the rocker panels and the hood.
Old Oct 18, 2010 | 12:08 PM
pattycakes77's Avatar
Reading the Durabak site, it doesn't say anything about fading. Did any of the 80 series people report any significant fading after sun exposure or chipping? I've been thinking of getting some of the Herculiner with the UV topcoat but this Durabak looks and sounds a bit more rugged. One last question, I see they say to remove the tape immediately after the second coat, did you have any trouble with the tape peeling the Durabak off the panels or any sections that the tape didn't want to come off easily? Nice job btw!
Old Oct 18, 2010 | 01:58 PM
vegaskurt's Avatar
The durabak 18 comes pre mixed with a UV protectant in it. They make an indoor use version of durabak that does not. Otherwise if you go with herculiner, you have to do an additional pass with their topcoat.
From what I have seen, herculiner has more of a sand paper texture, Durabak has more of a stucco texture. You can request a sample from durabak also on their site.
As for tape, no issues at all pulling it off. It took about 5 hours to remove the plastics, tape the inital line, sand, remove left over adhesive, sand some more, then clean with xlyene/MEK. Then to roll one side of the truck took me 12 minutes.
I did two coats, waited 15 minutes and pulled the tape while it was still tacky. One note about tape. Find this stuff:
I tried both the blue painters tape and the green painters tape you can get an an automotive store and neither would really bend correctly to do the wheel well line. With the Fineline tape I could use one strip of tape and go all they way across the truck and then just take a razor to where the doors open. Summit carries the tape. Best $7 I have spent.
Old Oct 18, 2010 | 02:40 PM
Thanks Kurt, yep I love that blue fineline tape, works wonders on so many projects. I'll get a sample and see if I like the texture, I do want something with some grit to it but not huge and blobby like some of the Rhino Liner I've seen. Thanks for the info.
Old Oct 19, 2010 | 09:59 AM
So Vega what type/kind of Durabak did you use for the rocker panels? I was just looking at their website and they have a couple of different kinds of their coating, including a 4X4 exterior coating, and truck bed liner. Is it all the same stuff or is there a difference? Finally, can that blue fineline tape be purchased at a local hardware or paint store or do I have to order it from Summit?
Old Oct 19, 2010 | 10:56 AM
Kerby J's Avatar
do you still have all the clips that came off the fenders for the flares i need them if so
Old Oct 19, 2010 | 04:14 PM
fillsrunner4's Avatar
do you have the side plastics? ide be interested to take them off ur hands if your not wanting them. Any pics?
Old Oct 19, 2010 | 04:31 PM
yoder519's Avatar
that looks niiiiccceeeeeeeee
Old Oct 20, 2010 | 04:18 PM
vegaskurt's Avatar
I ended up tossing the plasitcs, about half of the plastics that held them ended up breaking during the removal. I may have kept some of the clips but will have to double check.
As for the durabak. Its the Durabak 18 (with UV) color is just black.
Old Oct 23, 2010 | 08:18 AM
Bawlzdeep's Avatar
Looks good
Old Oct 23, 2010 | 05:25 PM
Thanks for the info! I just ordered up some Durabak so I'm hoping to coat the rocker panels and the sport hood I found on CL next weekend.
Also, does anyone know if you can buy the Fineline tape at a local hardware, auto, or paint store? I am hoping to find it somewhere so I don't have to order it.
Old Oct 29, 2010 | 11:35 PM
hopper's Avatar
how thick does it go on? Do you have a lip from the paint to the coating? Also how did you cover the holes in the body?
Old Oct 30, 2010 | 03:39 AM
dropzone's Avatar
Fossilized
see the red
Old Oct 30, 2010 | 08:44 PM
hopper's Avatar
Originally Posted by ocdropzone
see the red
Missed that one... and to think I looked to double check.
Old Nov 4, 2010 | 06:40 AM
I was finally able to do my rocker panels and hood this weekend. I must admit that I was nervous about using the Durabak on the rocker panels because it is pretty permanent stuff, but after seeing the results I'm really happy that I did it! I think it came out great and adds a whole new look to the truck! These aren't the best pictures, but here is how mine came out.
Old Nov 4, 2010 | 09:36 AM
that looks great. way better than plain white
