abs fuse link blown
Old Oct 21, 2010 | 06:33 PM
hgpotter's Avatar
abs fuse link blown
Abs light on after accident, damage to left front fender. after repairs found abs fuse link blown, new fuse will not hold. I get 4 different codes 11, 33, 34 and 49. Any idea where to start?
Old Oct 21, 2010 | 06:50 PM
DeathCougar's Avatar
Check the wiring, naturally. You have a wire shorting somewhere
Old Oct 22, 2010 | 04:02 PM
hgpotter's Avatar
abs fuse
I have been looking, nothing obvious yet. How do I get the fuse box apart to get blown fuse out, and where is the abs solenoid relay?
Old Jan 5, 2011 | 08:05 AM
Oldrupert's Avatar
I am also interested in where the solenoid realy is. I pulled the 11 and 34 codes from the abs.
My rear left axle housing seal went so I got gear oil all over my brake and abs sensor. Cleaned it off once but I will have to clean it off again.
But I don't know what to do about the 11 code. Is it a big problem? because the abs seems to work alright except for the RR wheel going on when it shouldn't.
Although sometimes the ABS light comes on steady and then the abs doesn't work at all until I shut off the engine for awhile.
80Truck
Oct 12, 2025 07:25 PM
sandyota
Feb 4, 2021 11:16 AM
Mrhoadley
Aug 4, 2015 06:08 PM
JHalcyonM
Aug 4, 2015 01:19 PM
ty1er
Aug 1, 2015 11:53 PM
