Gas tank + drive shaft!
Old Nov 19, 2010 | 11:06 AM
cordrayj1's Avatar
so i was doin a little wheelin a couple days ago...when i get near full flex in the rear, it sounded like something grabbin/pullin/and poppin from down below. i decided after that that maybe i should have put on those new bumpstops in the rear to prevent from flexin too far (2years ago when i originally put my lift on), so hopefully that will fix prob.
ANYways, has anyone else had this problem? i feel like i remember seeing this on a thread on one of the forums for 3rd gen 4runners.
Thanks!
Old Nov 19, 2010 | 11:10 AM
hross14's Avatar
yeah--if you increase the rear travel or mess with the rear suspension your Zirk fitting either hits the gastank or skid plate and shears off.....
Old Nov 19, 2010 | 11:11 AM
xxxtreme22r's Avatar
I have seen it in person, freakin scary as hell. Zeb8806 had this problem at Rausch Creek. I'll see if I can dig that thread up.
https://www.yotatech.com/forums/f116...s-tank-217373/
Old Nov 19, 2010 | 11:22 AM
cordrayj1's Avatar
so from the other post maybe i should look at replacing bushings? ill post up some pics of the setup after work...i got the adjustable pan hard bar from Steve at Sonoran steel, maybe its not adjusted correctly or something?
any thoughts on re-adjusting the bar's length? im not really educated on the exact cause and effect of adjusting it.
Old Nov 19, 2010 | 11:24 AM
can't help ya there, maybe shoot a pm over to Zeb8806 or RMA and see if they found a solution to theirs. Different gen I know, but might be the same problem/fix.
Old Nov 19, 2010 | 01:25 PM
hross14's Avatar
if you go to steves site he tells you what the length needs to be for a given suspension height increase.
If you didnt do anything to the rear suspension then why would you purchase the adjustable panhard bar?
Are we missing some detail here?
Old Nov 19, 2010 | 02:47 PM
cordrayj1's Avatar
i have the LC coils in rear w bilsteins. the sonoran steel 1.2 setup
Old Nov 19, 2010 | 02:49 PM
Zeb8806 also has or had I don't know for sure now, but when his D/S was hitting the tank he had the LC coils as well.
Old Nov 21, 2010 | 06:53 AM
crolison's Avatar
I had this problem too, i had ome 891s
Just beat the hell out of your gas tank skid where its hitting
Old Nov 22, 2010 | 01:22 AM
rocket's Avatar
lol yes
cordrayj1, There's two reasons why this skid plate was designed...
https://www.yotatech.com/forums/f39/...k-skid-216818/
https://www.yotatech.com/forums/f37/...unners-213292/
http://lilskipsoffroad.wordpress.com/
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
redneck17
Jul 17, 2015 07:44 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Jnkml
Jul 6, 2015 01:20 PM
