98 4runner 4cyl-4wd not engaging
Old Dec 10, 2010 | 03:17 PM
powrider686's Avatar
98 4runner-4wd doesnt work-HELP!!
Hi,
I tried to switch into 4wd the other day and to no avail. I checked vacuum and there is vacuum in only one of the hoses. I believe it is the 2wd vacuum line. When it is shifted into 4wd the vacuum does not switch tubes as it is suppossed to.
There are two vacuum hoses that go into the front diff. The one on the side had vacuum while the other did not. I have read that the vacuum should switch from the red to the blue vsv when the car is switched into 4wd. It does not switch at the vsv.
I will be checking if the wires coming into the vsv has power and switches when it is shifted into 4wd. If it does than the vsv is bad and I need to replace it. If it does not than my question is what controls the wires going to the vsv. If anyone knows where to look nixt that would be great.
Thanks!
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
