Tokico Shocks
Old Dec 15, 2010 | 08:19 PM
oddjob1370's Avatar
Tokico Shocks
After looking up Tokico shocks for my 00 4runner (SR5 V6 2wd) I found two.
P\N GU3564 (2wd)
P\N GU3535 (4wd)
Both should be the same for the 4runner mounting wise. I can't think of anything different for the shocks exept that the 4wd version might be valved for more weight then the 2wd version. I can't find any specs for them and my searches on here have come up with nothing.
Can anyone help me with what might be the differance between the two?
Old Dec 15, 2010 | 08:48 PM
scuba's Avatar
Thats going to be my best educated guess, too. I did a little searching but didn't find any real specs either.
Check this though:
https://www.yotatech.com/forums/f2/t...e-help-221001/
Old Dec 15, 2010 | 10:32 PM
oddjob1370's Avatar
well I have the GU3535's installed on OME 881's with the toytec top spacer. nothing is loose like that link you showed me. I was just wondering about the valving being firmer then the 2wd version. but I will install them and check it out once I get everything for the rear LC coil lift.
Any one running the GU3535 with the OME 881 and Top spacer on there 4runner or taco?
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
