Tokico Shocks
After looking up Tokico shocks for my 00 4runner (SR5 V6 2wd) I found two.
P\N GU3564 (2wd) P\N GU3535 (4wd) Both should be the same for the 4runner mounting wise. I can't think of anything different for the shocks exept that the 4wd version might be valved for more weight then the 2wd version. I can't find any specs for them and my searches on here have come up with nothing. Can anyone help me with what might be the differance between the two? |
Originally Posted by oddjob1370
(Post 51615746)
Check this though: https://www.yotatech.com/forums/f2/t...e-help-221001/ :dj: |
well I have the GU3535's installed on OME 881's with the toytec top spacer. nothing is loose like that link you showed me. I was just wondering about the valving being firmer then the 2wd version. but I will install them and check it out once I get everything for the rear LC coil lift.
Any one running the GU3535 with the OME 881 and Top spacer on there 4runner or taco? |
