Headlight question
Old Dec 13, 2010 | 12:42 AM
toy02's Avatar
Headlight question
My left front headlight is out. Changed the bulb, checked the fuse...still no dice. Right side works fine. Anything I need to check out?
Old Dec 13, 2010 | 12:56 AM
Lysmachia's Avatar
You using the Factory Service Manual for your year Truck? http://www.ncttora.com/fsm/index.html
Make sure you are checking the right fuse. If that isn't right use the FSM to troubleshoot the wiring. You may have an exposed or broken wire or ground....
Electrical gremlins are truly the worst! Good Luck!
Old Dec 13, 2010 | 05:31 AM
swampfox's Avatar
Check to see if you have voltage at the plug ,it also could be the plug needing cleaned or a bad ground.
Old Dec 26, 2010 | 11:22 PM
dirtymotoman's Avatar
Replace the fuse anyway. If that doesnt work check the bulb.
Old Dec 27, 2010 | 03:05 PM
tmolina's Avatar
Did you fix it yet? If so what was it?
mldave
Aug 10, 2015 09:23 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
