Steering play from 1st gen steering box
Old May 14, 2004 | 02:03 PM
deathrunner's Avatar
I recently replaced my pitman arm as there was play there. My idler arm is fine. I have limited the play to between my steering wheel and steering box. Is there any way to cure this. There are about 15 degrees of play. Thanks Seth
Old May 14, 2004 | 02:22 PM
eric-the-red's Avatar
I don't know about 1st gen but on the 2nd gen there is an adjustment on the steering box for free play. There's a slotted bolt on top of the box with a lock nut. Undo the lock nut and screw in the bolt to reduce play, then tighten lock nut. Manual says 1 inch of movement at the rim of the steering wheel is correct.
Old May 15, 2004 | 09:09 AM
Cool I'll check this out. So there is supposed to be an inch of play???? That's wierd I wonder if it would hurt anything if I tightened it to have no play.
Old May 15, 2004 | 11:21 AM
Well, I just tightened up that bolt and it sure tightened everything up like you said. I have much less play now. Awesome. After that I just had to realign the steering wheel onto the right splines. That sure sucked without a steering wheel puller. But I got it done. Thanks for the wise words. My Chilton's guide didn't even mention such and adjustment. If I ever come across this chilton's character......I tell you. They took my 25.00 for the guide and 3/4 of the time they don't have an answer.
Old Apr 15, 2006 | 07:10 PM
YotaJunky's Avatar
Hey Eric! Troy here. I just tightened up my steering box today on my 87 4runner (yes, I've still got it!). Anyway, I hope I did it correctly. As I was loosening up the lock nut, the slotted screw moved with it. I wound up snugging up the adjustment screw and then backing off about 1/8 of a turn. It sure felt tighter, but I've also heard that if it's too tight it can cause problems in the steering box.
Troy
Old Apr 15, 2006 | 07:29 PM
waskillywabbit's Avatar
No need for a steering wheel puller, just loosen the nut almost all the way off...the tap the steering wheel a few times, then pull it loose. Then take the nut off...if you take the nut off before it is loose...you'll eat the steering wheel.
Jun 1, 2021 01:51 PM
Scotto6591
Sep 1, 2015 03:24 PM
noahstancik
Jul 17, 2015 05:38 PM
msane99
Jul 17, 2015 10:13 AM
coryc85
Jul 6, 2015 04:07 AM
