Clutch question...
Old May 12, 2004 | 10:16 PM
mxracer0486's Avatar
Clutch question...
Ok today my clutch pedal started sticking to the floor, not all the time just once in a while, the weird thing is is that all though its stuck to the floor, its not engaged?!? Whats up?
Old May 12, 2004 | 10:32 PM
kyle_22r's Avatar
check your master and slave cylinder for leaks. could've blown a seal and you're not building any pressure
Old May 12, 2004 | 10:55 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
I agree w/ Kyle there... check your drivers side floorboard for leaks, that's where the master usually leaks from... follow the clutch pedal up and you'll see it. I typically replace them in pairs, both the master and the slave.
Old May 13, 2004 | 09:32 AM
kyle_22r's Avatar
i really need to replace my master, it's always leaked(well, every truck i've owned, the master leaked), slave popped 30 miles from home last year and i had to syncho shift all the way back don't think my clutch is far behind...it only grabs when i get to the top of the pedal now. maybe i'll get lucky and find a 50$ L52 tranny to dump in there for when that thing goes
Old May 19, 2004 | 06:22 PM
Well today I put in a new master cylinder, and the problem is fixed. It wasn't leaking, the plungers just gave away. I would like to thank you guys for your quick responses, they probly saved me money.
THANK YOU!
Old May 19, 2004 | 10:19 PM
bike4miles's Avatar
It's really easy. It only cost like $20 for the new cylindar and it just bolts on. Then you just have to pump some fluid into the system again and your good to go.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
