Which intake mod??
Old May 11, 2004 | 11:28 PM
WSU4runner's Avatar
Which intake mod??
I don't want to spend a ton on a K&N so I've narrowed my choices to these:
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
https://www.yotatech.com/~corey/tech...irbox/joey.htm
The first one looks a lot better but seems to be quite a bit more work. I'm mostly concerned about which one will be better performance wise. Thanks guys for your help.
Old May 12, 2004 | 08:07 AM
UKMyers's Avatar
Do em both and you'll basically have your own FIPK kit except it'll be better because the filter won't be completely exposed. If you don't have the skills for the ISR mod then at least pull that spoiler and tube out of the airbox it will yield noticable gains and give you a cool intake sound. It's only like 2 bolts and about a 5 minute job.
Old May 12, 2004 | 09:24 AM
bike4miles's Avatar
The air box mod is really really easy. If you are wiling to go through the work of replacing your stock air tubing, I would just do both. All you will have to do for the air box mod is drill some holes.
Old May 12, 2004 | 10:52 AM
WSU4runner's Avatar
Thanks guys, I'll go ahead and try them both. I thought the second one would be much easier but the first one looks a lot more professional.
Old May 12, 2004 | 11:35 AM
MTL_4runner's Avatar
It's not an either or situation.
The airbx mod will make the biggest difference overall though.
The ISR mod looks cool and will slightly increase power while making the engine MUCH louder at WOT.
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
Boomer8404
Sep 10, 2015 09:01 AM
