Vents
Old May 11, 2004 | 04:37 PM
Localmotion's Avatar
Vents
I have a 1996 SR5 and my center air vents only work. The sides work kinda of, but they only put out a little bit of air. Does anyone know how to fix this or am i just SOL :wtf:
Old May 11, 2004 | 08:29 PM
Andrey's Avatar
Did you fully open those side vents? There should be a little rotating nob on the bottom of those vents which regulates the air flow....
-- Andrey
Old May 11, 2004 | 11:07 PM
-- Andrey
haha...yea i did that...its just that it seems like a lot of airflow is not coming threw there....any other suggestions?
Old May 11, 2004 | 11:22 PM
LazuR's Avatar
How much airflow comes outa what vent is decided by what you have selected like "defrost" "defrost + feet" "Head" or whatever i can't think of the names or anythign so hopefully you know what im getting at... try moving that and see if you get a different result
Old May 11, 2004 | 11:53 PM
yea, when it is set at the head, the air flow is still very low. :pat: i was thinking along the lines of maybe the cabin air filter needs to be changed or is there someting blocking the vents for the driver side and the passenger side vents closest to the doors.
Old May 12, 2004 | 05:02 AM
lee's Avatar
lee
i dont know about yours, but my 01 has like basically a constant air flow coming out of there no matter what setting its on. its not as strong as whatever direction i set it in (ie, if i select head, the center air vents are strongest with a smaller wind coming out the sides... if i select feet only, the feet vents are strongest w/ a smaller wind coming out the sides. same for defrost, etc)
thats just how it is. if i want that air to stop, i have to close them. otherwise, its a wispy wind.
Old May 12, 2004 | 05:04 AM
lee's Avatar
lee
i think those are meant to be continuous (and not strong) for defrosting the side windows or something, namely because this winter, id turn the air flow toward the windows and theyd defog right away.
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
coryc85
Dec 5, 2015 08:42 AM
stanz
Oct 30, 2015 10:33 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
