4WD problem
Old Jan 5, 2005 | 03:18 PM
forum95's Avatar
Exclamation 4WD problem
As we all know winter is getting here, and the forcast expects snow very soon, so I decided to test my 4WD out. When I engage 4WD and start to gas, the car feels alot different, when i turn the wheel my truck bumps up and down and doesnt want to go foward (makes kind of like a harsh bumping noise) . Also when I release 4WD back into 2WD, sometimes there is a huge jolt in my truck which is rather loud, and my truck like slams down. Anyone know whats going on? I feel like something is about to break
BTW I do not have manual hubs
-Andrew
Old Jan 5, 2005 | 03:20 PM
89macrunner's Avatar
i dont know how much i can help you with this but specs on your vehicle would help people help you..i sugjest just putting your specs in your sig which makes it easier..
Old Jan 5, 2005 | 03:47 PM
superjoe83's Avatar
-Andrew
are you testing this on a hard surface? if so i think its working fine, its not meant to be used on high traction surfaces
Old Jan 5, 2005 | 04:42 PM
89_4runner's Avatar
This sounds normal if on dry pavement. Your transfer case will bind front/back when trying to turn in 4wd on dry pavement. When you put the truck back in 2wd the driveline tension is released and you hear clunks and the suspenion may settle back down.
Be careful about running in 4wd on dry pavement. If you had a viscous differential (like full-time 4wd) the binding is not an issue.
djpg2000
Nov 11, 2020 04:56 AM
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
