Throttle Cable Help
Old Jan 9, 2005 | 11:26 AM
drewberglund's Avatar
Question Throttle Cable Help
Hey everyone, I need a little help. How do I get slack out of my throttle cable? Got it off ebay and its shorter than my stock one (that Broke) but it has too much slack.
Also what is the best way to get a bolt out if it broke in half. Its from my thermostat cover.
Thanks
Old Jan 9, 2005 | 11:50 AM
node's Avatar
how much slack are you talking about. you should be able to adjust it with the two nuts that change the mount poing near the throttle. Make shure they are tight when your done
Old Jan 9, 2005 | 12:16 PM
I adjusted the nuts as far as they would go and still no luck. Is there anything else I can do??
Old Jan 9, 2005 | 12:21 PM
node's Avatar
sounds like you got the wrong cable. Is there an adjustment on the gas peddle itself? you could possibly shorten it there somehow.
some drunk guy
Aug 3, 2021 06:09 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
toyotafreak98
Sep 10, 2015 02:57 PM
