wheres the torsion bar?
Old Jan 11, 2005 | 05:48 PM
Chapman88SR5's Avatar
ok sry if this is a dumb question but i think i found it, if this isnt it can someone please point me in the right direction.
Old Jan 11, 2005 | 05:52 PM
ChickenLover's Avatar
That's the sway bar. The torsion bar is the black bar that begins at the front of the truck (near the shock) and ends under the doors.
Old Jan 11, 2005 | 05:53 PM
Corey's Avatar
Co-Founder/Administrator
That is your sway bar.
T bar is here.
Mine is white because it is aftermarket, the Sway Away 25mm ones.
Old Jan 11, 2005 | 05:54 PM
Glenn's Avatar
The torsion bar is straight and runs from the frame behind the wheel to the A-arm.
Old Jan 11, 2005 | 06:07 PM
ok sweet, i found the torsion bar, but is this the bolt i "crank"?
Old Jan 11, 2005 | 06:09 PM
yeah, the bolt on the bottom there.
Old Jan 11, 2005 | 06:10 PM
thanks for the help guys! im guna do this tommorrow and measure the difference, sorry for another guestion but what effects does this have on the ride?
Old Jan 11, 2005 | 06:14 PM
The more you crank the stiffer it gets. Most people don't go over 1.5 inches of 'crank lift' cause it puts the cv's at a gnarly angle. It takes quite a few cranks to get er movin' too. Mine are cranked about an inch or so and I have not lost any ride quality, but that's because I have about 145lbs of winch and bumper up front. If you get em too tight, you can always back em off a bit until you get the ride quality vs. lift you want.
Old Jan 11, 2005 | 06:16 PM
Oh yeah, when measuring your lift you should measure from the top of the rim, not the ground. It will be more accurate this way.
Old Jan 11, 2005 | 07:25 PM
ok cool, thanks for all the help, ill see if i can crank them an inch or so tomorrow
Old Jan 12, 2005 | 07:46 AM
eric-the-red's Avatar
Looking at the rust on that area I would recommend a generous dose of PB Blaster, WD40 or such the day before. Spray the top of the bolt where it screws into the nut. The good news is if you break one they aren't very expensive or hard to replace.
Old Jan 12, 2005 | 07:53 AM
86toyota's Avatar
But when they break, they usually put a nice hole in your floor.
Old Jan 12, 2005 | 01:10 PM
yeah it is really rusty under there, but most of it flakes off. ill eventually do some por 15 under there.
Old Jan 12, 2005 | 01:34 PM
mt_goat's Avatar
Here are some instructions for you: http://www.off-road.com/toyota/tech/torsion/index.htm
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
HiLuxer
Sep 9, 2015 02:43 PM
