newer used alternator in 82 4x4
Old Jan 6, 2005 | 07:32 PM
neil_P_smith's Avatar
Ok I have searched and I can’t find anything. I need to know how I should wire up my new alternator; it is one out of a newer truck and is the rounder type that has the internal regulator. It has a plug on the back of it that has three prongs two parallel and one perpendicular. Witch ones goes to what?? I am putting it in an 82 4x4 thanks a lot
Old Jan 6, 2005 | 07:36 PM
Yota4runner's Avatar
How much newer is the truck you pulled it out of?
Old Jan 6, 2005 | 11:57 PM
sorry it is out of an 86 4runner 22re
Old Jan 7, 2005 | 08:50 AM
kyle_22r's Avatar
for the trouble, why not get a cheap GM 1 or 2 wire alternator and make that work?
Old Jan 7, 2005 | 12:53 PM
Talking
i got it cheap and it is going to be a second altenator. i just need to know what prong goes to the egnition, batery and whatever els dont need a volt meater. trying to be simple, cheap, toyota
Old Jan 7, 2005 | 06:12 PM
Albin's Avatar
OK, here you go:
From the back, the three connections will look like this: |-| (roughly). The left vertical goes to the Ignition, the middle horizontal goes to the Sense and right vertical goes to the Lamp. These are the IG, S and L connections if you have your Toy FSM. The IG turns the alternator on, S provides the input for voltage regulation and the L operates your alternator lamp.
Just to the right of these three connectors is a brass bolt about 1/4" indiameter (but metric of course). This should go to the battery via the 80 amp fuse in the fuse box. Do not connect this terminal directly to the battery, ensue it goes through a properly sized fuse.
Speaking of wiring up a 1 or 3 wire alternator to the Toy system, here is my paper on how I did it with a 140 amp alternator from Summit Racing and Powermaster:
http://www.rocketcityrockcrawlers.co...lt_Upgrade.htm
I hope this helps.
Al
Old Jan 7, 2005 | 08:18 PM
Lightbulb
ok thanks a lot albin. i read your other page and this altenator is going to be a second one as i will leave the stock one in it. it looks like i can wire it up like this B = fused battery(? amp), IG = low voltage to ignition, S = low voltage to B, and L i could wire to a volt meater or leave it dead thanks Neil Smith
Old Jan 8, 2005 | 04:16 PM
so you guys think that it will work or not. i just need more power for lights and winch thanks NS
Old Jan 8, 2005 | 04:51 PM
Albin's Avatar
I don't see why not.
Let us know what happens.
Thanks,
Al
80Truck
Oct 12, 2025 07:25 PM
PNWrider
Oct 30, 2015 08:14 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Sep 4, 2015 09:27 AM
HRDC0R19
Jul 5, 2015 06:43 PM
