Weird sound from rear when downshifting??
Old Jan 9, 2005 | 10:01 AM
ARB4STUNNA's Avatar
I was wondering if anyone has seen or heard of anything like this?? On my friends 97' 4X4 Taco...when you are cruising about 30 mph and downshift to slow down there is a weird grinding sound coming from the rear. It sounds almost like the rear brakes grinding, however it does it even without applying the breaks. So far we have pulled the rear brakes apart and everything looks fine, shoes have plenty of meat no leaking wheel cylinders. He inspected the drive shaft and u-joints, and also changed the rear diff fluid and everything looks fine. The weird part is that it only does it when down shifting from a high speed...not when you hit the breaks. Any ideas would be appreciated. Thanks
Old Jan 9, 2005 | 09:29 PM
the_supernerd's Avatar
Is it when the clutch is slipping? If so, it might be the clutch. It might also be some sort of vibration caused by a loose mount.
Old Jan 9, 2005 | 09:59 PM
kyle_22r's Avatar
don't downshift! it's bad for the transmission...
Old Jan 9, 2005 | 10:02 PM
Downshifting at higher speeds wears the syncros. If you downshift like that, you should double clutch. Do not confuse it with speed shifting.
the1998sr5
15
Jul 14, 2020 08:35 PM
Liadrin
Sep 1, 2015 06:44 AM
icentropy
Jul 14, 2015 10:23 AM
mlavery85
Jul 12, 2015 10:33 AM
jon.r
Jul 11, 2015 03:34 PM
