tire inflator/deflator
Old Jan 11, 2005 | 06:08 PM
northfacer581's Avatar
i dont want to sound too stupid, but i do need some advice. even though it was about 65 today, winter is supposed to come to charlotte SOMETIME. and IF it snows (<--ha yeah right) , and for just "to have" reasons, i want something that come inflate my tires and deflate them. what are my options, because ive looked, and i found a few at jcwhitney that are aircompressor's but i havent found anything that can deflate them (dont laugh but i duno what you use to deflate them) and are the only 2 options of power to the air compressor, 12volt cigg. lighter and clipping to battery terminals? thanks for advice.
Old Jan 11, 2005 | 07:55 PM
Tacoma Dude's Avatar
FOR DEFLATING ONLY:
Maybe you should look into getting some Staun deflators? Here's a quick summary:
http://www.off-road.com/jeep/reviews...tiredeflators/
Contact Mike at http://www.xtremeoff-road.com
he's a good guy to deal with
Old Jan 11, 2005 | 08:30 PM
User 051420's Avatar
Search "on board air" or something like that...a lot of guys have hardmounted 100% duty cycle compressors in their rigs.
Old Jan 11, 2005 | 08:33 PM
Darx's Avatar
For deflating I just use my air gauge. Get a good quality one. Staun deflators are cool but pricey just for taking air out of your tires unless you're in a big hurry.
For inflating I have a crappy "TruckAir" that is slow but it works and I've left it on for quite a while and it's never given me a problem. If there's a gas station nearby though I use it instead or if someone offers to let me air up on their compressor I'll take them up on it.
I'd like to get a onboard compressor mounted in the engine bay some day.
Old Jan 12, 2005 | 03:56 AM
jacksonpt's Avatar
Senior Member
Deflating is the easy and inexpensive part. I have Staun Tire Deflators which I'm very happy with. I think I gave about $45 for the set of 4.
Inflating is probably going to be more expensive. You can get a cheap air compressor from Sears or the like for $50 or so, but it will take quite a while to air up from 20 to 35PSI. You can get a heavy duty compressor which will cut down the time it takes to air up (actual inflation time varies by compressor), but you're probably going to be looking at a minimum of $200 for the compressor. Good ones can push $400, or more. Another option is a CO2 setup. You can buy these as kits/packages from some off-road shops, or you can make your own using old scuba tanks and the like, air hosing, etc.
Do a search - onboard air topics have been covered in great depth on this board. There's lots of info out there, you just have to be patient enough to read though it all.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
