Inner CV boots have a small leak
Old Jan 8, 2005 | 09:46 AM
SLC Punk's Avatar
When I changed my oil, I noticed that my inner CV boots have a very small leak between the boot and axle. Since the leak is small, will I be ok just changing the clamp?
I did a quick search and only found "torn CV boot" questions.
Old Jan 8, 2005 | 01:35 PM
ASU4runner's Avatar
I'd check at NAPA for the right size clamps and go that route first. But go ahead and replace them before it's too late.
You'll have to cut the old clamps off. To make things much easier, buy new clamps that will fit around the boot/axle shaft without having to remove the axles.
Old Jan 8, 2005 | 04:01 PM
midiwall's Avatar
You can also head to Home Depot/Lowe's and pick up some hose clamps. You can get 'em nice and tight a lot easier than the standard crimp style clamps.
Old Jan 9, 2005 | 08:05 AM
Mad Chemist's Avatar
Be careful with the hose clamps, since some have experienced the "holes" in the hose clamp cutting the CV boot (just like they cut into a hose when tightened too tightly. A safer alternative is using zip ties and tightening them by pulling on the tab with a pair of pliers to get it nice and tight. I put zip ties near/on top of the OEM clamps.
Old Jan 9, 2005 | 08:07 AM
ASU4runner's Avatar
Good thinkin!!
Old Jan 9, 2005 | 08:13 AM
midiwall's Avatar
Understood, but... I've got ZipTies on one of my boots and had two issues - a) the head of the tie was hitting the lower arm causing it to slip and pull; b) smeared grease on the outside of the boot caused the tie to slip out of the ridges as I tightened it.
"b" is easily taken care of with a good degreaser bath before putting the tie on. But i didn't notice it until after it had been popped off "for a while". oops.
Old Jan 10, 2005 | 05:25 AM
SLC Punk's Avatar
Thanks for the info guys! The thing that makes me upset is the the dealer replaced all my CV boots because they said that the inner boots were leaking.. This was a few months after I bought it, so its out of their warranty.
Anyways, I will check with some parts stores and see what options they have.
Old Jun 27, 2005 | 12:15 PM
Yobroe's Avatar
Dealer response to leaking inner boot
I just lifted my 3rd gen and noticed some leakage on both my inner boots. I called my dealer service buddy and he said you don't have to worry about minor leakage. When I asked him if I should attach a hose clamp, it said that wouldn't be a bad idea, but now that I see the zip tie suggestion, it sounds alot better...
Cameron
Old Jun 27, 2005 | 12:49 PM
WATRD's Avatar
If grease is getting out, water is getting in. The joints are designed to operate in a sealed environment. It's nice that they didn't overstate the problem and make it sound like you needed a new half-shaft, but at the same time, telling you to run around with an open boot is not doing you any favors either.
BeMiceElf
Oct 10, 2015 09:40 PM
KyleT
Jul 21, 2015 07:54 PM
PlayAwhile
Jul 20, 2015 11:36 AM
nick b
Jul 11, 2015 04:38 AM
Avenged
Jul 9, 2015 07:55 AM
