97 4x4 taco suspension
Old Nov 16, 2005 | 05:32 AM
mudbog's Avatar
Hello, need some assistance here on a 97 4x4 taco 4cyl. I just picked up this truck last week, I think they beat the crap out of it cuz pretty much all of the suspension was shot. They must have taken it off road with all stock parts.
I changed out what I know: upper and lower ball joints, front struts, rear shocks, changed out some of the bushings, but now I'm worried about the Rack because it is very unstable when I go over any kind of bump while turning. I removed the boot and didn't see an inner tie rod - do the '97's have them and I just don't know what they look like? Any other thoughts on what else my problem could be? There's not much else I could even replace if I wanted to.
This is a good truck, just need to get the suspension thing taken care of before I can let my son drive it - Minnesota winters demand a stable vehicle.
Thanks guys!
Brian
Old Nov 16, 2005 | 05:48 AM
tc's Avatar
tc
Sounds like you might have a bad steering stabilizer. Easy and cheap to replace!
Old Nov 16, 2005 | 07:13 AM
93toy's Avatar
You said you changed some bushings, did you already change the rack bushings? Might clear up the slop and the poly kit is about $15.00
Old Nov 16, 2005 | 08:37 AM
mudbog's Avatar
I did not change the bushings on the rack cuz I thought they were ok. I did change the ones out on the stabilizer bar, those were shot. I can give it a try, it could be a pretty cheap fix.
I did the outter tie rod ends already. Are there inner tie rod ends on this model?
PNWrider
Oct 30, 2015 08:14 AM
Sep 4, 2015 09:27 AM
ripp96
Jul 25, 2015 02:32 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
