Throttle Body Overbore - TPS
Old Nov 17, 2005 | 01:10 PM
irott's Avatar
I have been looking into this and a few questions came up that I searched for but couldnt find the answers to.
What adjustments, if any, would need to be made to the Throttle Position Sensor?
Will the ECU need to be adjusted as well?
There just isnt much info on yotatech about this.
Old Nov 17, 2005 | 01:21 PM
snap-on's Avatar
no adjustments to the TPS the butterfly moves just as much/little as before it was bored
the ECU doesnt care, all the air has to pass over the flapper way down stream. Your just creating an easyer path for the air to flow into the intake plentum. (but still have to go through like a 3 sqin area were the AFS is.
Old Nov 17, 2005 | 01:45 PM
irott's Avatar
Thanks for the reply.
I found some more info on off-road.com about the TPS.
Old Nov 17, 2005 | 01:51 PM
rimpainter.com's Avatar
If you are simply doing a taper-bore to the butterfly, no adjustments are needed. I did it on mine. The gain, if any, was too small to detect.
Old Nov 17, 2005 | 02:27 PM
midiwall's Avatar
Ditto.
smthwsn357
May 1, 2024 07:28 AM
Blamalam
Mar 12, 2022 07:34 AM
jetpilot
Aug 15, 2015 06:48 AM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
