Can't get starter to turn. yyyyyy?
Old Nov 14, 2005 | 11:52 AM
Transfourmer's Avatar
I installed a new starter, tested the wire that connects to the starter solenoid and even tried to bipass it by running a wire straight to the 12v source with no luck , wont start the starter at all. No clicking or anything. The batter and grounding for the starter are all attatched. I just can't figure out why I can't get the starter to go. Any ideas?
Old Nov 14, 2005 | 12:13 PM
tc's Avatar
tc
What year, motor, etc?
I replaced the starter on my 89 22R, it was a piece of cake once I found out it was wired hot and should have disconnected the battery (a little arc event ).
The solenoid switches the ground I believe - hook both wires direct to a battery (with the starter on the bench) to test.
Old Nov 14, 2005 | 12:21 PM
its 89 3.0 So you mean that the little black wire that clips onto the starter - not the heavy gauge wires obviously - should just get a 12v power source to get the starter turning? I only see two wires on the starter, theres the heavy heavy gauge one that goes direct to the battery and then the small light gauge one that eventually makes it up to the steering column and the ignition switch. I don't want to pull the starter but as I rule out more and more possible problems, it seems more likely I'm going to have to even though I haven't gotten the car to start since I put it on.
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
