Any 2nd gen owners with front Husky liners ? READ THIS !
Old Nov 16, 2005 | 09:21 AM
nrgetic99's Avatar
I was just backprobing my ECU to check the setting and function of my Throttle Position Switch (TPS) and was not getting the right volts at the ECU for Wide Open Throttle (WOT).
After much furrowing of my brow, by a process of elimination, I discovered that my freakin Husky Liner was preventing me getting true WOT.
So, I remove liner and the volts at the ECU are magically correct. (~ 4.0V btw VTA and E2)
Quick test drive and the difference is apparent. From what I have learned, WOT triggers the ECU into a richer mixture at roughly 12:1 for maximum bmep and away from the optimum 14.7:1 (stoichiometric) for full throttle or WOT enrichment.
In short, truck go better now when I plant loud pedal
So, not sure if you have Husky's but I will be trimming mine under the gas pedal tonight... you may want to check yours.
David
Old Nov 16, 2005 | 09:35 AM
bdeakin's Avatar
I had this same problem with my '93 4Runner with large mats. After some trimming my 3.slow was a little bit faster. It didn't keep the throttle cable from getting stuck at full because of some loose nuts in the engine compartment. That was fun.
Old Nov 16, 2005 | 09:44 AM
lee's Avatar
lee
this has been said before, but in reverse... 'hey 2nd gen owners, i know how you can get better mpg's!"
Old Nov 16, 2005 | 10:17 AM
nrgetic99's Avatar
So I should add the mat back when my GF drives as a safety measure ???
David
Old Nov 16, 2005 | 10:40 AM
Gangus2006's Avatar
This makes me want ot go glue a small block of wood to the back of the skinny pedal ont he 4Runner.
Old Nov 16, 2005 | 11:24 AM
snap-on's Avatar
on my second gen the little rubber grommet thingie between the end of the throttle cable and the lever on the gass peddle was hossed, meaning i had like 1" of play in the peddle and there was no way i could get WOT. I've "afro-engineered" it for now, but need to come up with something a bit more permant that doesnt include replaceing the entire f'n cable.
Old Nov 16, 2005 | 11:44 AM
sandcrawler's Avatar
now i finally know why my rig's so slow! just needed the "husky liner WOT mod" :pat:
actually, among other things, i also need to tighten up my throttle cable, too.
Old Nov 16, 2005 | 12:07 PM
nrgetic99's Avatar
Doh ! Beat me too it....
I was going to add that exact line in my sig and wait for someone to notice and call me on it
David
Jun 1, 2021 01:51 PM
tpd143
Jul 7, 2015 09:06 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
Vargntucson
Jul 4, 2015 12:15 PM
